Kreb
Kreb UberDork
7/23/18 6:40 p.m.
So imagine a car with good g-loading potential being set up for autocross. The car has a crate small block Chevy with a mild cam, headers, intake,  HEI and Holley 4150 4-barrel.  My questions are if the carb will work in stock form, or should I be modifying the float and such? Also, will a stock oil pan be adequate to prevent oil starvation? Or should I be thinking of something with baffles and/or gates?
NordicSaab
NordicSaab Dork
7/23/18 6:46 p.m.
I would assume the lateral G forces in autocross are too short to be concerned with oil/fuel starve issues.  Perform preventative maintenance and have a good time :)
icaneat50eggs
icaneat50eggs Dork
7/23/18 7:03 p.m.
The important question is what is the SBC going into?  stop keeping us in the dark!
81cpcamaro
81cpcamaro Dork
7/23/18 7:20 p.m.
With street tires, you should be okay. As the grip level goes up, then a road race oil pan and/or accumulator would be needed. The carb should be fine, but if you do notice issues, there are road race floats available that help quite a bit. Longer sweepers usually will give you the most problems, short transitions and slaloms not as much.
Pete Gossett
Pete Gossett MegaDork
7/23/18 7:50 p.m.
In reply to Kreb :
From my research with the Vette a Holley double-pumper will handle Gs better than an Edelbrock. You may need race floats, jet extensions and a crossover tube. However, with the Vette on street tires I only ever had it cut out once on a very tight left-right combo. So you may not actually need those mods.
Kreb
Kreb UberDork
7/23/18 9:53 p.m.
Let's just say that the time is ripe with opportunities. smiley Thanks for the info, guys.
malibuguy
malibuguy Reader
7/23/18 11:08 p.m.
I can attest to Carter/Eddys not liking turns.  I even blocked off the internal crossover once in a past build in attempt to remedy that.  it didnt work at all.  I dunno what the trick is
STM317
STM317 SuperDork
7/24/18 3:28 a.m.
In reply to malibuguy :
The trick is fuel injection
2nNVnMIoU76T2LfbGk9Fqckb7EoQUv5fZJvRvhHLkltJ26wL2DJrA42SEo2ZRr2r
