Dusterbd13-michael
Dusterbd13-michael MegaDork
4/30/19 7:43 a.m.
I rented the tool that looks like a giant C-clamp at O'Reilly's last night. It doesn't have enough throat depth for the adapters and actually working. Call the round of the other part stores and there are none with a bigger throat depth. This is the lower ball joint on a 95 Silverado 2 wheel drive. Unable to beat it out with a 3lb hammer. Any ideas other than pulling the lower control arm and putting it in a hydraulic press?
Crackers
Crackers Dork
4/30/19 7:52 a.m.
Did you have the a arm supported? If it's loose and flopping around you lose a lot of force that way.
Dusterbd13-michael
4/30/19 8:05 a.m.
Sometimes the simple Act of posting the question gives the answer. Just figured out how to use the tool wrong and pushed out one of the two bad ball joint. Thanks for everything guys
Crackers
Crackers Dork
4/30/19 8:09 a.m.
Like asking future Mrs Crackers where my keys are. LOL
Dusterbd13-michael
4/30/19 8:21 a.m.
It aggrevates my wife so much when i do that......
Ranger50
Ranger50 UltimaDork
4/30/19 8:37 a.m.
That’s why I have the $600 Snap-on ball joint press. It’s saved me lots of time and effort.
mazdeuce - Seth
mazdeuce - Seth Mod Squad
4/30/19 8:40 a.m.
Off label tool use is a very important skill.
Vigo UltimaDork
4/30/19 9:16 a.m.
Yeah, whether it's a ball joint press or a shop press it's pretty much a puzzle. I have a hard time feeling like a professional when i use presses because in almost every case you feel like you're just making it up as you go. This is coming from a guy that teaches two suspension and steering classes today, so don't feel bad. Presses are just one of those things where you have very little specific guidance and have to use your own common sense and problem solving skills, which always feels angsty right up until you succeed and then feel like it was no big deal.
Stampie
Stampie PowerDork
4/30/19 9:50 a.m.
The big question is why they failed in the first place.
AngryCorvair
AngryCorvair MegaDork
4/30/19 9:54 a.m.
mark the LCA and the new LBJ so it is oriented correctly when you press it in.
Dusterbd13-michael
4/30/19 10:05 a.m.
In reply to Stampie :
Found many references to the supplied djm joints failing in short order. Consensus seems to be cheap, E36 M3ty parts. And comparing the failed to the moog, they are visibly lower quality .
Angry: moig gave an index on the joint. Sharpie gave one on the arm.
maschinenbau
maschinenbau Dork
4/30/19 10:50 a.m.
I once had a similar problem with a control arm joint using the parts-store tool. I went off-label with my usage...way off-label.
WonkoTheSane
WonkoTheSane Dork
4/30/19 10:58 a.m.
I'm so glad you thought to document that... I do stupid e36 m3 like that and I always forget to take a picture :)
Professor_Brap
Professor_Brap Dork
4/30/19 10:58 a.m.
In reply to maschinenbau :
Im impressed, yet scared.
frenchyd
frenchyd UberDork
4/30/19 11:00 a.m.
Two big hammers, one on either side of the ball joint. Hit together and joint pops like a teenagers pimple.
maschinenbau
maschinenbau Dork
4/30/19 11:02 a.m.
In reply to Professor_Brap :
There was significant bowing of that 2x4.
GfqzL3geIr2GW2Bjx6hlZDgBOqjkmM1nApE8rbh2wOgnltpIfDarrDssE6je7AwH
