Looking for some input from the hive on my currently in-operative Prius
The culprit: 2012 PriusV - original battery ~160k miles
What happened:
Drove it 1/2 mile to grocery store and parked it (put in P). Left it on with ac and radio going. The smart key was in it with a driving-age passenger in the passenger seat.
I came out of the store about 10 minutes later and the radio and blower fan were still running but 'all' the dash warning lights were now on.
At this point I tried to shift to drive or reverse and it would not go into either position, just neutral.
I tried turning it all the way off and back on and it would not go to Ready mode which is necessary to select drive or reverse.
Suspecting 12v battery had drained down too low, I tried jumping with a jump box under the hood with no change.
Tried jumping it from another vehicle under the hood, no change.
Tried jumping it from jump box straight to the 12v battery in the back, no change.
Reset the 12v by pulling the ground and traction battery by pulling the big orange interlock
On the next attempted start, a bunch of messages showed up on the dash for a second and quickly went away.
At this point I gave up and waited for a tow.
Hoping that it was just a weak 12v battery causing computer problems, I had it towed to a local goodyear.
They ran some diagnostics and said that the 12v battery tested good, the interlock tested ok and it has two codes:
P0A0D - hybrid safety interlock problem detected
U0110
When I look up U0110 the generic code definition is - U0110 Data bus: drive motor control module - no communication - Some internet searches regarding this code point towards the inverter.
But, What the shop put in the notes is: U0110 High energy battery malfunction detected
And so they quoted me a replacement battery and said 'that usually fixes the problem'.
So, I want to get a 2nd opinion and not replace the battery if a) I don't have to & b)its not actually the main problem (I'm sure it has some weak cells).
Do I take it to a dealer? Which one in the Dayton, OH area? Find a good independent hybrid specialist? Suggestions?
I'm not troubleshooting it myself but I want to have some confidence that it's been properly diagnosed.
