WildScotsRacing
WildScotsRacing HalfDork
7/20/16 12:42 p.m.
The question is, should my air dam fasteners be painted black to blend in with the air dam?
edizzle89
edizzle89 Dork
7/20/16 12:43 p.m.
i would say if you have time it would look better painted, but i wouldnt sweat it if they didnt get painted... because racecar
The Hoff
The Hoff UltraDork
7/20/16 12:51 p.m.
I would paint them to match. That being said, it looks fine with them raw. Very GRM.
(Coming from a guy with a plywood splitter )
trucke
trucke Dork
7/20/16 12:55 p.m.
Leave the fasteners alone. Looks industrial which makes it more awesome! If you paint those, the paint will eventually begin to peel making it look like @##%^&.
WildScotsRacing
7/20/16 1:01 p.m.
The Hoff wrote: I would paint them to match. That being said, it looks fine with them raw. Very GRM. (Coming from a guy with a plywood splitter )
Yeah, kind of my feelings too. It's just going to have to get re-done after a four-off at a wrong spot on the track, anyway. Here is some more GRM style: my sealed radiator inlet duct made from mylar film and urethane adhesive! The rad is now boxed all the way around woth this stuff.
7/20/16 1:01 p.m.
trucke wrote: Leave the fasteners alone. Looks industrial which makes it more awesome! If you paint those, the paint will eventually begin to peel making it look like @##%^&.
Sad truth, even though IMO painting them would look better (in the short term at least).
Klayfish
Klayfish UberDork
7/20/16 1:35 p.m.
Yes, paint them...if you can do it without them peeling.
Stefan (Not Bruce)
Stefan (Not Bruce) MegaDork
7/20/16 1:48 p.m.
I would look at anodizing them, which would avoid the peeling issue and should hold up to being removed and reinstalled if necessary.
Sometimes you can even find fasteners that already black from places like McMaster-Carr, etc.
chiodos
chiodos Dork
7/20/16 1:59 p.m.
In reply to Stefan (Not Bruce):
You can diy anodize. I can't remember which chemicals you need and if its the same for aluminum and zinc/whatever coated steel but its really simple and you can get the two chemicals from walmart or homedepot and use ritz clothes dye from walmart, any color you want pretty much.
Stefan (Not Bruce)
7/20/16 2:55 p.m.
In reply to chiodos:
Exactly what I was thinking.
RevRico
RevRico HalfDork
7/20/16 2:57 p.m.
I personally like them shiny. But I believe in the "can't see it from the drivers seat" theory as far as most aesthetics go.
Trackmouse
Trackmouse Dork
7/20/16 3:02 p.m.
Lol. The easiest diy anodize ever- a sharpie. Nearly free. Doesn't peel. Can be redone anytime.
Boost_Crazy
Boost_Crazy HalfDork
7/20/16 3:16 p.m.
In reply to Trackmouse:
It amazes me how well a sharpie holds up. I picked up energy suspension motor mounts for my car at a junkyard. The red mounts didn't go with my sleeper looking engine bay, so I colored them black with a sharpie. It has lasted for years.
dean1484
dean1484 MegaDork
7/20/16 3:30 p.m.
Replace them with black oxide fasteners and you should be good to go.
mndsm
mndsm MegaDork
7/20/16 3:34 p.m.
Paint is heavy. Bare metal makes it go faster.
rslifkin
rslifkin Dork
7/20/16 3:37 p.m.
mndsm wrote: Paint is heavy. Bare metal makes it go faster.
But if you fill in the recesses in the screw heads, does the aero benefit help more than the extra weight hurts?
wearymicrobe
wearymicrobe UltraDork
7/20/16 4:28 p.m.
On a car like that does paint make it go faster. If no then leave alone.
mndsm
mndsm MegaDork
7/20/16 4:30 p.m.
Good question. Run unpainted, paint, run again?
Knurled
Knurled MegaDork
7/20/16 4:38 p.m.
They do sell colored rivets.
ebonyandivory
ebonyandivory UltraDork
7/20/16 4:57 p.m.
Plasti-Dip with a small brush or Q-Tip.
Peel it off if you need to access the head.
oldopelguy
oldopelguy UltraDork
7/20/16 9:19 p.m.
Black nail polish after a good cleaning.
Or colored, actually, if that is more your style.
WildScotsRacing
7/21/16 12:41 a.m.
Hah! On a car like this, even taking a good dump first makes it go faster!
7/21/16 7:52 a.m.
I'm fine with the exposed fasteners, but I have a high tolerance for stuff like that.
In reply to the question you never asked, I would bring the black on the rockers up another 2" to the fold line in the door, and add a yellow border like you did on the skunk stripes.
Brian
Brian MegaDork
7/21/16 7:58 a.m.
Bare is fine, sharpie if you must.
Tyler H
Tyler H SuperDork
7/21/16 8:13 a.m.
Are those screws? After years running crapcan races, here's my PSA: Back those puppies out one at a time and replace them with a big rivet and backing washer.
Sheetmetal and wood screws end races.
7WQgQAqfPYBh9jWhSua8JOHjODdnZYJbdXfV48g6GpmiiYKLywZtRNFzx7n8EioE
