Indy-Barely Functional-Guy
Indy-Barely Functional-Guy SuperDork
5/14/18 2:16 p.m.
I need a cheap aftermarket temperature gauge for the $100 Fiero.
Needle broke off:
Any recommendations?
Professor_Brap
Professor_Brap Reader
5/14/18 2:28 p.m.
eBay.com
5/14/18 2:33 p.m.
Sunpro gauges, for all your cheapass gauge needs! Although I bet you could super/hot glue that needle back onto whatever was turning it.
Robbie
Robbie PowerDork
5/14/18 2:38 p.m.
edizzle89
edizzle89 Dork
5/14/18 2:39 p.m.
i was also going to say Sunpro, i got one of there generic 'set of 3' gauge panel things with oil pressure, volts, and coolant temp for around $25 on Amazon. The coolant temp gauge was mechanical which i did not realize, not much harder to run then an electric gauge but requires slightly more attention to routing.
bentwrench
bentwrench SuperDork
5/14/18 2:42 p.m.
You don't need a temp gauge, if it's not steaming it's not over heating.
Look at similar vintage GM's for a gauge donor? S10 might be a good donor.
Installing aftermarket gauges is so cheesy when the factory stuff is there it only takes one wire.
It appears by the crack in the lens someone has violated it, you may need a whole gauge panel.
5/14/18 2:57 p.m.
Unless it's an aluminum block engine, in which case the first sign of overheating is your block getting gooey enough to ruin the flatness of the block-to-head seal.
5/14/18 3:03 p.m.
In reply to Professor_Brap :
OEM gauge is high $$$
5/14/18 3:04 p.m.
I'll check them out. Not gonna try to glue it on.
5/14/18 3:05 p.m.
Robbie said:
How does $6 sound?
https://www.harborfreight.com/electronic-triple-auto-gauge-set-41017.html
That link shows $17.99 for me.
5/14/18 3:06 p.m.
I should have said, cheap AND easy to install.
5/14/18 3:08 p.m.
This is literally a $ 100 car. Looks don't matter. And yes, YES a lot on this car has already been violated.
grover
grover Reader
5/14/18 3:14 p.m.
is this a challenge car? Would be cool to use some type of cooking gauge instead of a regular car gauge.
Robbie
Robbie PowerDork
5/14/18 3:37 p.m.
Indy-Barely Functional-Guy said:
Robbie said:
How does $6 sound?
But you are getting 3 gauges, soooooo
Robbie
Robbie PowerDork
5/14/18 3:40 p.m.
It's basically just measuring a resistance (or voltage drop across, but same thing), so you could dig up one of the free HF multimeters and hook it up. Or, go find an old school style multimeter with the swinging needle and use that, but replace the faceplate on it.
All of this feels like a lot of work though.
5/14/18 3:42 p.m.
Interesting.... How would you pull that off?
5/14/18 3:44 p.m.
OK, so school me the difference between mechanical and electrical gauge?
edizzle89
edizzle89 Dork
5/14/18 3:45 p.m.
They aren't necessarily hard to install, just a little harder to route the metal line vs. pulling wires where you want them to go
also forgot we're talking a fiero here, not sure if the mechanical temp gauge has a long enough lead to get to the engine. you could do like they did on Roadkill with the mid-engine dragster and mount the gauge behind the seats facing forward where they could see it in the rear view mirror. you can see the 2 gauges just over Freiburger's head.
5/14/18 3:45 p.m.
Robbie said:
How does $6 sound?
Oh, understood. wink
Robbie
Robbie PowerDork
5/14/18 3:47 p.m.
for coolant temp not that much. but the idea is mechanical gauges actually measure at the gauge, and electrical ones just measure a voltage or resistance reading taken by a sender. Most oem stuff will be electrical if made in the last say 50 years. Cheap gauges will tend to be mechanical.
Mechanical coolant temp means there is a copper conductor that you need to route from your engine bay to your dashboard (one end is threaded into a coolant port like a temp sender, and the other is threaded into the gauge). You cannot cut or splice this conductor or the gauge will not work.
5/14/18 8:36 p.m.
In reply to edizzle89 & Robbie:
Thanks for the info.
JBasham
JBasham HalfDork
5/16/18 8:08 a.m.
Bosch install package
This one is $23 from the Zon.  But (1) it works great (2) it comes with a mounting bracket (3) it comes with an extensive set of adapters for the sensor (4) it's dead easy to install.  So, you're pretty much guaranteed to get it installed for nothing more than the $23 entry price.
I use it to monitor the intake water temp on the Fubari at the track, where the oil pan temps are running as high as 250-260F.
Robbie
Robbie PowerDork
5/16/18 10:56 a.m.
In reply to JBasham :
That's a great deal on an electrical gauge. I'll have to remember that.
Trackmouse
Trackmouse UltraDork
5/16/18 11:02 a.m.
minivan_racer
minivan_racer UberDork
5/16/18 11:07 a.m.
On a Fiero I'd spend the extra on a electric gauge so routing is easier.  If the gauge uses a separate sensor from the one the ecu uses (assuming it is an efi car)  replace the factory sensor with the aftermarket gauge one and use the factory wire running up to the cluster.
DBoy0sZ1yFrPGoi8OB1evsrSsku6NtJeQTHhrFwx6mbqAhZ5LIcAU647vOT4r8OZ
