stroker
stroker Dork
5/12/14 8:37 p.m.
Is there some master chart indicating turbo size/configuration by number?
jpnovak
jpnovak Reader
5/12/14 9:08 p.m.
I just looked at the EFR map again. I did not pay attention to the scale on the contour lines. You do not often see a 76% efficient contour plot. It is quite broad if you look at a 72% island line.
I do wonder if it is a little large for my boost requirements following a Pressure Ratio of 2. I am concerned about compressor speed. Since it is slow it might also be slow to spool for my particular configuration. Though I need to do a few more calculations. Thanks for the suggestion. Now if I could find one a bit cheaper I would be more convinced.
Leafy
Leafy Reader
5/12/14 9:11 p.m.
Use the match bot. If you give it real data, and map out the turbine plot it seems to pretty accurately show the boost threshold rpms with whats actually possible. I tested that.
xlzBZGk4XmgFN8RAlnKg2l9eBy0Qgz25wdEtYgXTJi1bvFRATBUMK8cbQpOUYDBn
