joey48442
joey48442 UberDork
4/30/12 7:56 p.m.
I want to make my own headlight wiring for the xj in preparation for an ecode conversion. What gauge wire would be best, an what size relay? Also, where do I buy the light socket with no pigtail, as it's usually 18 gauge wire, and I plan to go a bit bigger gauge.
Also, should I do the same with the Miata, where would I tie into at? The battery is in the trunk...
Joey
unevolved
unevolved Dork
4/30/12 8:28 p.m.
Mouser has them.
Part number 649-PPI0000813, Link
They're $1.50 each and they have them in stock. Here's a drawing to check the measurements and make sure it's the right one:
Here's a 23-page data sheet on the connector:
http://portal.fciconnect.com/Comergent//fci/documentation/mu_br_004_ppi0000813_lamph4.pdf
novaderrik
novaderrik SuperDork
4/30/12 8:36 p.m.
junkyards are full of cars that can donate these kinds of electrical plugs for pennies.. you just need to remove the existing wires- which usually involves a small flat blade screwdriver inserted from the front to release the tang so you can pull the terminal out from the rear..
EvanR
EvanR Reader
5/1/12 1:43 a.m.
also try www.candlepowerinc.com
joey48442
joey48442 UberDork
5/1/12 8:18 p.m.
Thanks for the links guys!
Joey
ITOqWAwIkDpFM6PbFT7443QmPMVP4QC02mUsc5hau97UelllEEyVHBG46rio5sRZ
