alfadriver
alfadriver UltimaDork
11/9/15 2:20 p.m.
People seem to forget that an intake is just a BFV.
ultraclyde
ultraclyde UltraDork
11/9/15 2:39 p.m.
Dusterbd13 wrote: Holy E36 M3
QFT
RossD
RossD UltimaDork
11/9/15 2:57 p.m.
Streetwiseguy
Streetwiseguy PowerDork
11/9/15 4:32 p.m.
It must have been said a couple of times already, but your car sucks, dude.
Paul_VR6
Paul_VR6 Dork
11/9/15 9:16 p.m.
Well, that explains it.
44Dwarf
44Dwarf UltraDork
11/10/15 9:04 a.m.
1/2 x 1/2 alum Angle riveted in place would fix that. Might block some flow but it should be a vast improvement
alfadriver
11/10/15 9:20 a.m.
44Dwarf wrote: 1/2 x 1/2 alum Angle riveted in place would fix that. Might block some flow but it should be a vast improvement
The flow blockage is why it sucked in. Up util the flow got high enough, it was fine.
bradyzq
bradyzq Dork
11/10/15 9:23 a.m.
Looks to me like that hole needs to be bigger. With a bigger opening, the pressure drop across the scoop would be lower. Making the same scoop out of stronger material would still have the pressure delta, and, though maybe it wouldn't collapse, you'd still be losing power.
11/10/15 9:37 a.m.
Easy & cheap solution, grab some aircraft scissors and cut along this line:
That will decrease vacuum under the scoop and should let air through even if the scoop collapses.
kb58
kb58 Dork
11/10/15 6:47 p.m.
Easiest and cheapest, remove scoop... for now.
oWxUeTm1K1fpSP5ac01FkFSMDpLG3Nlq2qwGtRdd3tf51Ke7iXTUPdQ6ctFwW3ZE
