DukeOfUndersteer
DukeOfUndersteer SuperDork
12/11/10 3:59 p.m.
Update: Everything went back together, battery in, STARTS!!
Bad news: a chunk of the head where the exhaust cam seals sits had a chunk missing when i took the cam out. 3 little crumbled pieces came out when i took the upper cam cover off. Well, i thought i could hopefully get around it with a new seal in, sealed up. Didnt work. At idle, oil was getting around that seal and dripping down the block and water pump, ect. So, needs a new head or jimmy-rigging of JB Weld on the exsisting head.
So bummed and depressed that i got everything back together and it starts and idles fine, but pukes oil. Oh well, gotta start ripping it apart again...
fornetti14
fornetti14 HalfDork
12/12/10 7:55 a.m.
I'd try the JB weld first. Really clean the area and goop that stuff on. It may take a few layers.
There might be something other than JB weld that holds it's shape better. When you try and goop JB weld into a large area it tends to run.
I'd finish off the area with a few layers of RTV.
Not the proper way to do it but crazier things have worked on this board.
tuna55
tuna55 Dork
12/12/10 1:14 p.m.
fornetti14 wrote: There might be something other than JB weld that holds it's shape better. When you try and goop JB weld into a large area it tends to run.
Yes there is, it's called regular weld. Just weld a glob on there and machine the rest off - no RTV or other gobblty gook.
IWELDIT
IWELDIT New Reader
12/13/10 7:09 p.m.
PM sent
HK7eGNF31yUE4CkgBHtL84akbIvedB7Il5wOkx6MAOTPIjh1nirCELk20q2dnJsQ
