I had to change the thermostat housing to clear the firewall on my engine swap and in the process add another radiator cap to the system. Is this a problem? I'm planning on only running a catch can from the rear cap and plugging the outlet on the front cap, is this a stupid idea?
Thanks.
Make sure the cap at the highest point is the cap that feeds the overflow. Use a non relief cap on the other one.
kb58
Dork
2/15/15 7:58 p.m.
You'll be fine - just do as Boost Crazy recommended.
Or, if for some reason a non relief cap is not available, the one at the lower point should have the higher relief pressure of the two, preferably by several psi.
I usually run two caps. Both get routed vent lines to the overflow. The cap at the higher elevation get a lower pressure rated cap.
How about some details. Turbo 4 e30s are cool
Should be easy to purge air.
amg_rx7
SuperDork
2/16/15 12:33 a.m.
That's how Mazda did it on the FD. They also added an Air Separation Tank like the more modern Vette's have.
In reply to mr2peak:
http://grassrootsmotorsports.com/forum/build-projects-and-project-cars/1987-bmw-325e-motor-swap-project/83313/page1/
