Toyman01
Toyman01 MegaDork
2/3/16 5:57 p.m.
Which is better.
I have a small gravity pot that works fairly well. But I'm considering sandblasting the exterior of SanFord.
If a pressure pot is substantially better I'd consider buying one. I have enough compressor to push either one without a problem.
Toyman01
Toyman01 MegaDork
2/3/16 6:04 p.m.
Another question. Will soda blasting remove rust?
captdownshift
captdownshift UltraDork
2/3/16 6:40 p.m.
In reply to Toyman01:
Absolutely, it's fantastic at it.
spitfirebill
spitfirebill PowerDork
2/3/16 8:20 p.m.
That's news to me.
And I would say a pressure pot is better than a siphon feed.
Grtechguy
Grtechguy MegaDork
3/21/16 5:31 p.m.
I'm bumping this.. What did you end up using?
Toyman01
Toyman01 MegaDork
3/21/16 5:56 p.m.
In reply to Grtechguy:
I bought a water sandblast kit for my pressure washer from Northern Tool. I haven't had time to try it yet, but I'll post here when I do.
Video of one being used. Not Me.
https://www.youtube.com/embed/BUx1RZKfB-E
jimbbski
jimbbski Dork
3/21/16 7:03 p.m.
FYI. Water blasting steel is OK but it will flash rust almost as fast as it dries. You can remove the rust with a phosphoric acid solution that will also leave a coating that you can paint over with etching primer.
etifosi
etifosi Dork
3/21/16 7:48 p.m.
Soda blasting will NOT remove rust.
cMg5QIFBkjhqhTNYX6NhIP7BTX8ibkW8oN2fdJMRVIwLkl5k8uqsV4Rh1HsA5w65
