accordionfolder
accordionfolder HalfDork
8/1/16 2:28 p.m.
Hey guys.
On the Exocet I've had to install a bunch of grounds to the frame. I bought some specific "self tapping screws." They only appear to have a 70% success rate.
Is there a "nut-sert" style no weld solution for more cleanly installed grounding screws?
Is there a better "self tapping screw" I'm not using?
Any other input?
Thanks
Trans_Maro
Trans_Maro PowerDork
8/1/16 2:32 p.m.
I like Tek screws for grounding: http://totallynutsandbolts.com/tek_screws.html
alfadriver
alfadriver MegaDork
8/1/16 2:33 p.m.
I have one of these from HF- and they work great- http://www.harborfreight.com/hand-tools/hand-riveters/3-in-1-riveter-kit-94100.html
Even found which drill bit is barely big enough for the threaded insert- so it's nice and tight.
stafford1500
stafford1500 Reader
8/1/16 2:35 p.m.
Weld studs on the chassis for the best answer. If you want riv-nut type application, you can get a stud type. The problem with riv-nut type installations is they have another surface to keep in contact to the chassis. Corrosion can start in a place you can't see or service...
kb58
kb58 Dork
8/1/16 3:11 p.m.
I weld screws upside down on near-by chassis tubes and presto
accordionfolder
8/1/16 3:14 p.m.
stafford1500 wrote: Weld studs on the chassis for the best answer. If you want riv-nut type application, you can get a stud type. The problem with riv-nut type installations is they have another surface to keep in contact to the chassis. Corrosion can start in a place you can't see or service...
Yeah, that's what I suspected. My welder is half way across the country, but now needing to do some exhaust work and this I might just get a cheap-oh harbor freight one....
accordionfolder
8/1/16 3:17 p.m.
In reply to kb58:
Obvious good solution is obvious post discover, lol.
In reply to Trans_Maro:
Good option, I was using "generic" self tapping screws. I might just order some of the real deal if I don't weld in studs or nuts.
In reply to alfadriver:
Thanks for the recomendation!
motomoron
motomoron SuperDork
8/1/16 4:38 p.m.
I generally use 10-32 rivnuts for small grounds on my race car. I do clean off any paint where it's going and put a smear of sealant around it after. They've all been perfect for ~5 years.
6k1lIjCAEBKBbd97zDrzeQ755LDYnK4nDCTdPXVkXkuOgGpVUPk278rB5OZ1uuFy
