Raze
Raze Dork
3/14/11 7:07 a.m.
Just wanted to make sure someone has done this and it's ok to do. The plug wires on the Fiat are waaaaaaaay too long (hang all over the place). I need to shorten them but just wanted to make sure this isn't a bad thing to do.
Thanks!
JThw8
JThw8 SuperDork
3/14/11 7:14 a.m.
As long as you do it correctly it shouldn't be a problem. No different than using one of the DIY universal, cut to length plug wire kits.
Nashco
Nashco SuperDork
3/14/11 11:58 a.m.
I do it all the time, I hate plug wires too long...they usually end up chaffing or burning on something when they're too long anyway. It takes a little finesse, especially with used wires, to keep from tearing the silicone wire jacket when you're moving the boot around. Getting the crimps loosened up enough to re-insert the proper length wire is also a little tricky...I find that really small sidecutters/dikes work best to dig in and pry up until you can get a small flat blade or similar in there. Otherwise, it's pretty straight forward.
Remember, it's easy to shorten a wire, but it's really hard to stretch one!
Bryce
ncjay
ncjay Reader
3/14/11 12:35 p.m.
I make most of my own plug wires. As with most things, the right set of tools makes it much easier. There are crimping pliers made just for plug wires. I usually wind up using WD-40 or something similar to make moving/removing the boots a touch easier. If you have an ohmmeter handy, it's not a bad idea to check the wires before and after to make sure they still have good connections.
Raze
Raze Dork
3/14/11 3:40 p.m.
Thanks guys, luckily these wires are pretty 'loose' from the factory and are new, I pulled the boots back from all 4 plug ends and yanked one of the plugs off by hand. I just wanted to make sure I didn't need some fancy tools to make these things. I can't wait to cut them down and reduce the chance of burning/chaffing which is exactly what concerns me!
alex
alex SuperDork
3/14/11 5:05 p.m.
Now I feel spoiled. The only time I've made/modified plug wires is on motorcycles, and pretty much any plug boot just screws down into the wire. It's a nice system.
novaderrik
novaderrik HalfDork
3/14/11 6:59 p.m.
it's easy to do- i've done it with only a set of pliers and a utility knife. you can reuse the terminals if you're careful- but if you want to do it "right", go to NAPA and buy however many new terminals you think you'll need, plus a couple of extras just because. they should have them in a box somewhere- the box will probably be faded and covered with a layer of dust and only the oldest of old timers that works there will know where to find it, but it should be there..
pVJQwhids5NuklBmANRLsB5anbmhIY7Ns9WrCNGMCz6bIRURAmmwkRMWBxUa4Ulx
