stroker
stroker SuperDork
6/11/16 9:25 a.m.
Bobzilla wrote: Dude... the Suzuki Verona 2.5L! Actually.... I wondered what one of those in a Locust would sound like.
From what I hear those Verona mills are chronically bad. Warp the head, replace and repeat in 20,000 miles...
stroker
stroker SuperDork
6/11/16 11:10 a.m.
by the way, does anyone know if a straight six Ford was used in the Fox Body Mustang or was it always a V6?
Knurled
Knurled MegaDork
6/11/16 11:24 a.m.
Not sure about the Mustang, but you could get the 200 in a Fairmont. It had a different subframe from the 4/8 cylinder.
bentwrench
bentwrench Dork
6/11/16 11:32 a.m.
Isn't the Fairimont a Fox chassis in drag? (equivalent vintage)
The 200 has a horrific cylinder head, with a crossflow it would rip!
Isnt there some hot rod goodies from down under to fit that?
Javelin
Javelin MegaDork
6/11/16 11:52 a.m.
Uh, TVR?!?
Jumper K. Balls
Jumper K. Balls UberDork
6/11/16 12:06 p.m.
The 200 inline was indeed in the mustang and Capri for a year or two.
Knurled
Knurled MegaDork
6/11/16 12:17 p.m.
bentwrench wrote: Isn't the Fairimont a Fox chassis in drag? (equivalent vintage)
Backwards. The Fairmont is the ur-Fox. It's the Falcon to the Mustang's... err... Mustang.
fasted58
fasted58 UltimaDork
6/11/16 12:18 p.m.
Several area dirt tracks had a 6 cylinder class back in the 70's, basically American inline 6 in a street stock chassis. Surprisingly good racing though lower car counts as compared to V8's, they eventually faded away.
So, on to road racing. Once engine/ chassis rules are ballparked who will sanction these classes? SCCA, NASA would seem appropriate for road course. Don't any inline 6 racers already have a class? as in Datsun Z cars, BMWs, Triumphs etc., not to mention vintage.
stroker
stroker SuperDork
6/11/16 7:58 p.m.
Oh, I guess I'm not envisioning something as formal as that. Just struck me as the sort of thing you could build with cast-off F150's using cheap Fox performance stuff. If you showed up at your local SCCA event with one mebbe somebody else would build, one, too...
Adrian_Thompson
Adrian_Thompson MegaDork
6/11/16 8:10 p.m.
Why straight 6 only? Why not V or flat?
Does the cam(s) count as part of the head or do they have to be stock too?
What about diesel?
Adrian_Thompson
6/11/16 8:12 p.m.
What about diesel?
stroker
stroker SuperDork
6/11/16 8:26 p.m.
Don't suppose you couldn't do the V/H sixes as well, but it seemed like the cheap inlines from GM/Ford/AM were a place to get started on something that would be cheap and different. If you think a Corvair is the way to go... :)
Edit: We figured the cams, porting and induction would be fair game...
fireball123
fireball123 New Reader
6/11/16 9:25 p.m.
Adrian_Thompson wrote: Why straight 6 only? Why not V or flat? Does the cam(s) count as part of the head or do they have to be stock too? What about diesel?
If your going flat six rout Porsche makes some high powered six cylinders
Adrian_Thompson
6/12/16 1:19 p.m.
I wonder what my motivation was for asking
fasted58
fasted58 UltimaDork
6/12/16 1:32 p.m.
stroker wrote: Oh, I guess I'm not envisioning something as formal as that. Just struck me as the sort of thing you could build with cast-off F150's using cheap Fox performance stuff. If you showed up at your local SCCA event with one mebbe somebody else would build, one, too...
I like the I-6 concept, to simplify chassis/ weight differentials maybe a spec type chassis like Locost previously mentioned. Realistically, I could see that happen.
JimS
JimS New Reader
6/12/16 3:36 p.m.
Back in the 70's I believe IMSA had a an RS series where some i6's were raced. I think Amos Johnson ran an AMC Gremlin and I think an AMC Spirit. Not sure if there were other sixes racing. Just googled and it was a 232.
stroker
stroker SuperDork
6/12/16 3:54 p.m.
Okay, so Fairmont, Falcon and early Mustangs do the Fords. Darts and Valiants for Mopar, Hornets, Gremlins and early Ramblers for AMC, Nova (and Apollo, et all) for GM. What other model/candidates can you think of?
dropstep
dropstep Dork
6/12/16 4:07 p.m.
The 200 ford is pretty much useless for an NA class because of the terrible head design. Be better off using the 300 or its smaller displacement version thats escaping me right now.
Knurled
Knurled MegaDork
6/12/16 4:42 p.m.
dropstep wrote: The 200 ford is pretty much useless for an NA class because of the terrible head design. Be better off using the 300 or its smaller displacement version thats escaping me right now.
The 240?
I have seen some interesting things done with the small six with respect to brazing flanges to the intake manifold for multiple SUs/motorcycle carbs. I think it'd be neat to take a head and just drill/endmill/bore straight in and stick tubes in the ports, like making a peripheral port rotor housing.
Should be even easier, in theory, because you wouldn't have to seal it to coolant and you wouldn't be crushing the tubes when you assemble the engine. (The problem I ran into when I tried fabricating my own peripheral port)
Then a couple short lengths of hose and you can run DCOE carbs, throttle bodies, fabricated plenum manifold, whatever you want.
dropstep
dropstep Dork
6/12/16 8:49 p.m.
If i was building a 200 for anything the first thing id try too track down is the aluminum head and intake that classic inlines was selling. But even then they advertised it as a 20% horsepower increase and it was 1500 for the bare casting.
The NA 200 record was 15.60 in a gutted falcon last i looked. Not alot of horsepower per dollar NA.
stroker
stroker SuperDork
6/12/16 11:17 p.m.
dropstep wrote: If i was building a 200 for anything the first thing id try too track down is the aluminum head and intake that classic inlines was selling. But even then they advertised it as a 20% horsepower increase and it was 1500 for the bare casting. The NA 200 record was 15.60 in a gutted falcon last i looked. Not alot of horsepower per dollar NA.
What about the 250 Chev?
edizzle89
edizzle89 Dork
6/13/16 6:40 a.m.
i got another vote for the 4200 vortec straight 6. they have 275 hp out of the gate, with some head work i'd imagine you could get a decent bump in power from there.
DLPe0S8G08rORKnoCkTqz3ZE81oKtIBAeTUiTCB8L0CeZR6dWrf9i2H4Zed6J27j
