wvumtnbkr
wvumtnbkr SuperDork
12/26/15 11:39 a.m.
Chumpcar now has a class to roadrace these.....
chada75
chada75 Reader
12/26/15 2:37 p.m.
In reply to wvumtnbkr:
That would be entertaining when he needs to turn right.
wvumtnbkr
wvumtnbkr SuperDork
12/26/15 4:41 p.m.
Why? Chassis was listed as no offset.
Besides, there is a grmer who races an offset chassis for hillclimbs and does well.
I think it would be perfect t!
XLR99
XLR99 HalfDork
12/26/15 4:46 p.m.
Would you be able to title/reg this as a self-assembled car, regardless of the body panels you stick on it?
physician
physician New Reader
12/26/15 5:18 p.m.
A prius is listed as 106.5 in wheelbase.... Early ones with high millage ones are cheap.. under 1000$. Selling non used bits may bring its challenge value to 500$... A prius has a low drag coefficient.. may not be a big advantage for challenge though
iceracer
iceracer PowerDork
12/26/15 6:09 p.m.
Most of the race versions used a ? Cavalier body.
mr2peak
mr2peak Dork
12/27/15 1:51 a.m.
physician wrote: A prius is listed as 106.5 in wheelbase.... Early ones with high millage ones are cheap.. under 1000$. Selling non used bits may bring its challenge value to 500$... A prius has a low drag coefficient.. may not be a big advantage for challenge though
A body dropped prius would be amazing. Talk about unexpected.
patgizz
patgizz PowerDork
12/27/15 8:32 a.m.
the other problem i'll run into with a newer body is anything 25 years or newer needs emissions tested. unless it's got a simple way to make the computer "lie" to the emissions testing equipment(obd2) then it won't get plates, won't get driven on the street, and would be a waste of time.
i may have something more than old enough soon, might be getting one of my old cars back.
JohnRW1621
JohnRW1621 MegaDork
12/27/15 10:41 a.m.
You can register it to my house if that helps.
No emissions testing in my county of Ohio.
On CL there are some rusty 80's Malibus. The slab side bodies should lend to easy fit ala Roadkill style.
EvanB
EvanB UltimaDork
12/29/15 8:31 a.m.
How about this?
http://columbus.craigslist.org/cto/5378397833.html
Indy-Guy
Indy-Guy UltraDork
12/2/18 8:23 p.m.
Did anything ever happen with this?
It still haunts me thinking about the possibility of the old school ride Appleseed posted on the first page:
Patrick
Patrick MegaDork
12/3/18 1:20 a.m.
I cut it up.  At some point water got inside the frame rails and blew them up from the inside out.  Traded the quick change for a wad of cash, kept the front suspension intact as a rolling clip for future use.
5ua6b0n6KwXj2HR8Xc1UpuJObMqdL0rLowxbm7bIG13fKxLoysrZv0DnufPLL7VA
