KyAllroad
KyAllroad Reader
9/14/14 9:01 p.m.
I was AutoXing today as well. Irksomely the morning heat had none and my Hoosiers didn't do much gripping on the 55 degree asphalt. The afternoon heat was SO MUCH faster!! At least in two weeks the worm will turn and then....
84FSP
84FSP New Reader
9/16/14 7:35 a.m.
So jealous of your events. I haven't been out to an event since I finished up the rabbit. Trying to make the last race Oct 5th. Unfortunately I'll just be off a plane from Asia the day before so wonder how jet lag autox works...
jstein77
jstein77 SuperDork
9/16/14 8:16 a.m.
I was autocrossing too on Sunday. Our central Florida event had lots of heat; 90 degrees of it. I'm so ready for the cooler weather to set in next month.
Had a good day.
Link
Thinkkker
Thinkkker UltraDork
9/16/14 11:21 a.m.
Pffft. Went out this past Sunday. First time I was out in 3 years, on 3 year old tires, and left the kids seat in the back. Finished 11 in PAX. I am out of practice
Woody
Woody MegaDork
9/16/14 11:38 a.m.
If I could share one piece of advice with anyone who is just getting into autocross, it would be this:
Try not to have an eleven time national champion in your class.
Harvey
Harvey Reader
9/16/14 1:43 p.m.
Yeah, having Daddio driving the z06 against you can be a bit disheartening, but then again it's great competition!
To be fair he only got that car a couple of months ago. He might do even better later.
Looks like I managed to pax fourth. I'm all about pax now that I'm in GS
jstein77
jstein77 SuperDork
9/16/14 2:44 p.m.
Harvey wrote: Looks like I managed to pax fourth. I'm all about pax now that I'm in GS
I used to be too when I had my GS Sentra. The SMF index is a lot tougher, so now I'm happy if I make the top 10. I actually place better on raw times than on index (5th overall, 8th in PAX on Sunday).
Mr_Clutch42
Mr_Clutch42 Dork
9/16/14 3:41 p.m.
In reply to Woody: I found out that for just starting out, half the field is most likely to beat you right off the bat, and to not worry about losing too much.
Harvey
Harvey Reader
9/16/14 5:55 p.m.
I used to run SSM in my turbo Miata so I've gone the opposite direction from you.
Harvey
Harvey Reader
9/16/14 5:57 p.m.
Of course Mark Daddio won both raw and pax FTD so there isn't much we can say on that front.
Woody
Woody MegaDork
9/16/14 6:07 p.m.
Mr_Clutch42 wrote: In reply to Woody: I found out that for just starting out, half the field is most likely to beat you right off the bat, and to not worry about losing too much.
Oh, I'm not new at this. I started autocrossing 28 years ago. I just haven't done it in a while. Winning was never as important to me as just having a good time with my car. Which is convenient, because I'm not very good at it.
Harvey
Harvey Reader
9/16/14 9:31 p.m.
Come on out to our event on the 28th and say hi or I will if I see you there.
Woody
Woody MegaDork
9/16/14 9:47 p.m.
Thanks, but I can't. I have a prior obligation that day.
Dusterbd13
Dusterbd13 Dork
9/17/14 6:28 a.m.
Woody, that's exactly why I do it as well. Id prefer to run hpde, but the cost of consumables, and the greater risk involved, hold me back right now.
Woody
Woody MegaDork
9/17/14 8:08 a.m.
I think that autocrossing is much harder on a car than a track day.
wbjones
wbjones UltimaDork
9/17/14 9:09 a.m.
autocross may be "harder" on the car …. we're at WOT in 2nd gear and throwing the car around rather violently …
that said, the higher speeds, longer harder braking, lateral loads, heat build up, plus the greater opportunity of impact damage would seem to make DE's more of a problem in the long run … at least to me … my 2¢
Harvey
Harvey Reader
9/17/14 10:10 a.m.
Track days are harder on a car. You don't use up brakes at an autocross, you aren't running your engine at high RPM for long at all, tires don't get worn down all that much at autocross. You just aren't driving the car for very long at autocross as compared to a track day where you might be out there beating on the car for a half hour at a shot or more.
Autocross amounts to maybe 10-15 minutes of hard driving per event for a car. Usually less if you're a one driver car.
JHe4jW4WS4NREszDGfzRiVOAehKflqSU2dzbY7hM0k25Ij4gI657eTz0naAfBhEO
