procainestart
procainestart SuperDork
2/10/25 6:39 p.m.
Do we have a preferred source from which to order low quantities of rubber seals, o-rings that isn't Amazon or eBay?
2/10/25 6:50 p.m.
First place I'd look would be McMaster-Carr.
Harbor Freight has sample packs of various sizes as well.
procainestart
2/10/25 7:15 p.m.
M-C is what prompted the question: they have what I need... in packages of 50. It's not terribly expensive, though, and who knows, maybe I can come up with something creative to make with 49 31x25x3 o-rings. ;-)
2/10/25 7:24 p.m.
You could always buy a foot of 3mm O-ring cord (Viton, neoprene, whatever you want) and glue up an O-ring yourself.
I'm surprised that you have a minimum order of 50.  I've ordered weird sizes from McMaster-Carr (O-rings to fit Mazda rotary oil scrapers) and was always able to order as many as I needed.  So I checked.... and I've never seen that before!
50 cheap O-rings for $15 or ten Viton O-rings for $10.  If you only need one, why not save money and get Viton?
Trent
Trent UltimaDork
2/10/25 7:29 p.m.
It also matters what you are sealing. fuel? oil? coolant? brake fluid? The O-ring needs to be compatible with the goo you are trying to keep out.... or in.
Nitrile, Viton, rubber, ect.
The HF assortment has a close match, but not spot on
procainestart
2/10/25 7:58 p.m.
In reply to Pete. (l33t FS) :
Yeah, I was surprised at the quantity, too. Other sizes listed in the search results were available in smaller quantities (e.g., two, five).
The O-ring is for a Saab PCV system that is a PITA to get to and is only available with terrible seals that apparently leak pretty much immediately, which is why I want to source my own (and avoid HF). Never occurred to me to make one; I'll have to remember that.
I ended up buying the 50; they're n-Buna, so should be okay. I fully recognize that they were inexpensive to begin with; I just prefer to buy only what I need...
2/10/25 8:24 p.m.
TIL that they no longer sell 2.2mm cord of any flavor.  You need a few meters of 2.2mm Viton to make rotary inner coolant seals.
Outer are 2mm, but they can be anything.  I've used 18ga electrical wire smiley
porschenut
porschenut Dork
2/11/25 8:22 a.m.
For seals I have a local bearing supply house that has been very helpful.  For O rings again an industrial supply business nearby has spent more time than the sale was worth to help me.  Sometimes local beats the internet.
NorseDave
NorseDave HalfDork
2/11/25 5:11 p.m.
Based on the website, it appears Fastenal will let you buy singles.  I would assume shipping is likely more than the O-ring cost, but if you're near a Fastenal store I think you can just ship it to the store for free.
2/11/25 7:06 p.m.
So now you have 49 decent o-rings that Saab owners want. Sounds like the beginning of a small business:)
Pushrod
Pushrod Reader
2/11/25 7:26 p.m.
Your local NAPA should have a good selection, too...
1988RedT2
1988RedT2 MegaDork
2/11/25 8:29 p.m.
I was poking around for something in a specific material and found a company right here in Richmond, VA area that sold small quantities for very reasonable.  No storefront, ship only.  If I can find it, I'll edit this post.
Edit:  Found it!
https://www.oringsandmore.com/
As I recall, they didn't have a minimum order, or it was very reasonable.  Very helpful over the phone. This was maybe five years ago.  YMMV.
Datsun240ZGuy
Datsun240ZGuy MegaDork
2/11/25 9:24 p.m.
Opposite - I have a supplier that sells Parker o rings with crazy 500-1000 MOQ.
Interestingly the MOQ always fell close to $1000-$1200.  The guy always offered Chinese versions but my OEM only wanted Parker brand.
stuart in mn
stuart in mn MegaDork
2/12/25 6:38 a.m.
In reply to Trent :
That HF assortment has me confused.  It says petroleum products, but then it also says non-aromatic fuels and solvents.  Gasoline is a petroleum product but isn't it also an aromatic fuel?
procainestart
2/14/25 2:56 p.m.
Ha! I'm already a bit of a parts hoarder -- it would make my wife happy if I got rid of some of the stash, so a small business would probably be good...
2/14/25 2:59 p.m.
stuart in mn said:
In reply to Trent :
If you want to be more confused, the "metric" and "SAE" assortments have the same O rings inside, but the "metric" set costs more.
I'd think that by now, SAE anything should cost significantly more, not less, than metric.
ZfpoWxOw8wMtCCsFWdQQo5UlEXwfextOkdaKydCOakFrnzd44rSY6xF5LcyfyJcV
