noddaz
SuperDork
2/28/18 7:53 p.m.
Backround, 2002 Ranger whacked in the right front. I have all the parts to put this together but have been trying to avoid replacing the core support. I just can't get the RF structure to pull out to where I want it using a come along and my 4WD F250. So it looks like I need to drill out the spot welds holding the core support in. Will HF tools do this? Or do I need something more industrial?
noddaz
Tyler H
UltraDork
2/28/18 8:59 p.m.
For a one time job like this, HF works. Keep it lubed with wd-40, moderate pressure and speed.
I drilled out engine mounts when I was putting a 3SGTE into my mk1 MR2 with HF spot weld bit. No sweat.
A pneumatic air chisel is helpful.
I don't hate the harbor freight spot weld cutter. It does its thing as well as expected but I have kinda gone off the spring plunger hole saw type and now use these
http://Dent Fix DF1680T 8.0mm Titanium Spot Weld Drill Bit, 1 Pack https://www.amazon.com/dp/B00AZAE4VQ/ref=cm_sw_r_cp_apa_Dc4LAb19ZFA43
I get them off the snap on truck
Both are only part of the equation. Another big part is one of these
http://Steck Manufacturing 20015 Seam Buster Chisel https://www.amazon.com/dp/B000JFJMJ6/ref=cm_sw_r_cp_apa_qf4LAbPARJCKH
Invaluable.
SkinnyG
SuperDork
2/28/18 11:00 p.m.
I've used the HF equivalent, and they worth with minimal (but definitely WITH) swearing.
I've also ground old drill bits into the spot weld bit shape, which is essentially a center-point wood drill bit.
Are you drilling spot welds with the intention of replacing a panel? I presume so- In that case, I will forgo the spot drills and just use a 3 inch cut off wheel to grind away the panel that I am discarding. Centering and depth of cut is a pain with a spot cutter, and you will often leave a thin spot on the saved panel right where you want to weld.
No, if you are going to the junkyard to get a panel to re-use, drill the spots out with a regular bit, because you don't care about the under panel.
Spot weld cutters get used if I need to remove a panel, and save it for re-installation onto the same panel, which doesn't really happen that often.
Just my opinion, I could be wrong.
noddaz
SuperDork
3/1/18 6:21 p.m.
Thank you all. I do have a new core support in the pile of parts. So as soon as the weather clears again, a grinding-cutting-mangling I will go. Once I have the core support out I "know" the right inner structure will pull right out.
noddaz
