Adrian_Thompson
Adrian_Thompson Dork
11/3/11 12:02 p.m.
Wow, look at this. If this had been built today people would call it steampunk style, but it's from 1923. Well this is actually a recreation as the original was crashed, but wow, just wow! Story: http://www.switchimage.org/Lefebvre_1_E.html
JoeyM
JoeyM SuperDork
11/3/11 12:18 p.m.
Odd....I like it
93EXCivic
93EXCivic SuperDork
11/3/11 12:20 p.m.
I wanna build one!
monark192
monark192 Reader
11/3/11 12:23 p.m.
Kinda unique
MG_Bryan
MG_Bryan Reader
11/3/11 12:24 p.m.
I'm fascinated by the air-powered water pump.
914Driver SuperDork
11/3/11 12:35 p.m.
Any idea what powers the beastie?
Taiden
Taiden Dork
11/3/11 12:37 p.m.
Is that a steam engine?
93EXCivic
93EXCivic SuperDork
11/3/11 12:37 p.m.
In reply to 914Driver:
The power plant was a valve - less six-cylinder sleeve engine; while it could not reach high revolutions, it developed phenomenal torque. The engine was very quiet and produced 80 bhp.
No idea if it was bespoke or off the shelf. It doesn't say.
Winston
Winston Reader
11/3/11 12:45 p.m.
Amazing. I love how almost all of the body panels can be made with flat sheet aluminum formed in a single plane.
Rusted_Busted_Spit
Rusted_Busted_Spit SuperDork
11/3/11 1:34 p.m.
From the article:
He was the first in the racing world to abandon the traditional chassis with a separately mounted body, and build a monocoque body shaped like the fuselage of an aircraft. It was built like a plane, as well. Its light wooden frame was metal braced and clad with riveted sheets of aluminum, forming a strong unit while keeping the weight below 750 kg. The bottom was completely flat, giving the air stream a smooth passage underneath the car. Wooden vanes streamlined the suspension attach points to improve the airflow.
Very cool.
914Driver SuperDork
11/3/11 2:27 p.m.
93EXCivic wrote: In reply to 914Driver:
I reread the article, Valveless? Anyone got 10 minutes to explain that one?
a401cj
a401cj Reader
11/3/11 2:41 p.m.
needs an LSX ....just sayin
HappyAndy
HappyAndy HalfDork
11/3/11 2:47 p.m.
I reread the article, Valveless? Anyone got 10 minutes to explain that one? Sleeve engine. It has moving sleeves in the top end instead of valves. Think of a 2big stroke with moving ports.
MG_Bryan
MG_Bryan Reader
11/3/11 3:08 p.m.
Didn't feel like digging for a better diagram.
Edit: berkeleying hotlinks... See video: http://www.youtube.com/watch?v=NSMYjRNQ8Rs
Adrian_Thompson
11/3/11 4:00 p.m.
I love the wind powered (through the prop on the front) water pump
ThePhranc
ThePhranc Reader
11/3/11 4:46 p.m.
Needs more brass!
stuart in mn
stuart in mn SuperDork
11/3/11 6:19 p.m.
My high school girlfriend's dad had a 1929 Willys-Knight with a sleeve valve engine. It was a very smooth running engine, but it was inherently a smoker. Guess they weren't worried too much about emissions back then.
mr2peak
mr2peak Reader
11/3/11 10:53 p.m.
Probably a two-stroke, hence the lack of valves and the torque.
aircooled
aircooled SuperDork
11/3/11 11:28 p.m.
Sleeve valve engines have ports in the sides of the heads (like two strokes), but also have holes in the cylinder "sleeve" or bore. The sleeve is rotated in a similar way that a normal valve train is (a bit more complex obviously) to line up the holes in the bore with the holes in the head.
I believe they are supposed to be a bit more efficient, as you can imagine the ports would flow a LOT better then a poppet valved head. But obviously they are a good amount more complex also.
The most successful sleeve valve engine that I know is the Bristol Centaurus that was installed in the Hawker Sea Fury.
Here is a shot of the gear (valve) train (!):
Here you can see the ports and the sleeve (yellow):
Here is a Sea Fury:
It should be noted that a number of the flying Sea Fury's have had the Centaurus engine replaced with "normal" valved American engine. Centaurus engined planes can be distinguished by the 5 bladed prop, re-engined ones are 4 bladed..
JoeyM
JoeyM SuperDork
11/4/11 6:11 a.m.
aircooled wrote: Sleeve valve engines.... is (a bit more complex obviously).....But obviously they are a good amount more complex also. The most successful sleeve valve engine that I know is the Bristol Centaurus that was installed in the Hawker Sea Fury. Here is a shot of the gear (valve) train (!): />
ultraclyde
ultraclyde HalfDork
11/4/11 6:16 a.m.
THAT looks like a steampunk award winner! No way I'd go aloft on that
iceracer
iceracer SuperDork
11/4/11 9:33 a.m.
Willys-Knight had sleeve valve engines. Biggest problem was oil consumption.
Basil Exposition
Basil Exposition Reader
11/4/11 9:46 a.m.
Voisin was a major innovator and is famous for his somewhat quirky, but unique designs.
Here are a few others. Check out the "Mylord". If the Munsters could have afforded it....
http://www.supercars.net/Search2?INPUT=Voisin
He built several cars for the Grand Prix de Tours in 1923, you can find some period pics here:
http://www.motorsnaps.com/v/1920s+Racing+Cars+and+drivers/1923/French+Grand+Prix/g1923gp+de+l_acf_+tours+-+andr__+morel+voisin+laboratoire+d.jpg.html
PS122
PS122 Reader
11/4/11 1:39 p.m.
This must have been the inspiration for the Audi/VW timing chain arrangement...
ZtsKO4T3SdGyHrX0rtznd5r58ZcoQLjZ3bjriCH26wUYAJCjV5I68xWW2PSk6jp8
