914Driver SuperDork
3/29/11 8:31 a.m.
Msogren's Jetta popped up at the bottom left side of the screen, it came from Readers' Rides. Why is it lifting its leg?
If it's a turn left car, wouldn't you want 15" wheels on the right and 13s on the left enhancing left turns? The car appears to be empty in the photo.
Dan
ditchdigger
ditchdigger HalfDork
3/29/11 8:41 a.m.
There is a driver in there. It is just a FWD VW cornering and lifting its inside rear
914Driver SuperDork
3/29/11 9:14 a.m.
OK, didn't see the driver in ths small photo.
Thanx.
Slyp_Dawg
Slyp_Dawg HalfDork
3/29/11 10:53 a.m.
it's lifting it's leg for the same reason nearly any race prepped (or even street car with sporty suspension) FWD car will lift it's leg cornering: weight transfer. also, I don't think oval racing rules will allow you to stagger wheel diameters. you can stagger wheel widths and tire diameter/tread width all day every day, no problem, but I've never heard of staggered diameters being used
Zomby woof
Zomby woof SuperDork
3/29/11 11:00 a.m.
I used to run 5" of stagger on my mini stock. Not sure how it would work on a FWD car.
Nonetheless, this just came up on the bottom left of my screen, and it looks equally as awesome
kazoospec
kazoospec New Reader
3/29/11 12:04 p.m.
Just guessing, probably has a rear beam axle like my SE-R. On a fast sweeper, the inside rear wheel will sometimes hang in the air long enough to stop spinning. Looks pretty cool with three of four wheels going like crazy and the fourth sitting motionless in mid air. I'm told its a sign I need more front spring, but it helps rotate the front end, so I kind of like it.
BTW: That pose is affectionately known as the peeing dog or the three legged dog.
killerkane
killerkane Reader
3/29/11 12:24 p.m.
My old Focus ZX3 did that, but it was sprung too tight. Seems like all of the Evo's I see do the same as well.
92CelicaHalfTrac
92CelicaHalfTrac SuperDork
3/29/11 12:27 p.m.
My Celica has and does do that as well.
jimbbski
jimbbski Reader
3/29/11 12:30 p.m.
When I work corners at some track that have long turns you can watch some FWD cars lift the inside rear tire and carry it all the way through the turn. Some wheels will stop spining, some keep spining. The more stock the car is the higher the wheels lifts, or so it seems. Not all FWD cars will do this. It has to have a beam axel that doubles as a sway bar. Mark I VW's ( Rabbits & Scriocco's) are one example.
neckromacr
neckromacr Reader
3/29/11 12:50 p.m.
jimbbski wrote: When I work corners at some track that have long turns you can watch some FWD cars lift the inside rear tire and carry it all the way through the turn. Some wheels will stop spining, some keep spining. The more stock the car is the higher the wheels lifts, or so it seems. Not all FWD cars will do this. It has to have a beam axel that doubles as a sway bar. Mark I VW's ( Rabbits & Scriocco's) are one example.
Actually VW has been using rear beams in all the A chassis up until the A5 (2003 and newer) and now have back pedaled a bit by using beam rears on the lower ended A7 chassis.
Probably why the peeing dog stance was so well know in the VW community
dculberson
dculberson Reader
3/29/11 12:51 p.m.
Zomby woof wrote:
That .. is incredible. Must have some serious brakes and great rubber.
iceracer
iceracer Dork
3/29/11 1:54 p.m.
My ZX2SR even with independant rear suspension would lift it's inside rear. I believe it has a lot to do with weight distrbution.
911's lift the inside front wheel. Or you can get technical about roll couple distribution.
HStockSolo
HStockSolo New Reader
3/29/11 1:57 p.m.
jimbbski wrote: Not all FWD cars will do this. It has to have a beam axel that doubles as a sway bar. Mark I VW's ( Rabbits & Scriocco's) are one example.
No, all it requires is enough rear stiffness. All my stock DOHC Saturns did it and they have independent rears and fairly small rear sway bars. My Storm stopped lifting as much when I put a much stiffer rear bar in. My stock SC2 has also lifted both rears on occasion.
killerkane
killerkane Reader
3/29/11 1:58 p.m.
I've seen an FSAE car (without aero) lift wheels both front and back depending on load.
DILYSI Dave
DILYSI Dave SuperDork
3/29/11 2:40 p.m.
dculberson wrote:
Or a bigass bump just off camera. ST EF's have E36 M3ty brakes and marginal rubber. There's no way that's a stoppie.
Twin_Cam
Twin_Cam SuperDork
3/29/11 4:43 p.m.
kazoospec wrote: BTW: That pose is affectionately known as the peeing dog or the three legged dog.
Fire hydrant salute!
I was under the impression that any stiffly-sprung FWD car with good rubber on the wheels could pull one.
John Brown
John Brown SuperDork
3/29/11 4:51 p.m.
DILYSI Dave wrote:
Or maybe someone photoshopped out the jack stands ;)
wbjones
wbjones SuperDork
3/29/11 5:22 p.m.
jimbbski wrote: It has to have a beam axel that doubles as a sway bar. Mark I VW's ( Rabbits & Scriocco's) are one example.
not so... I have a pic on the wall behind my work bench at the plant of my '01 Integra on 3 wheels mid-corner.... 400# front springs, 550# rear springs... 22mm rear sway bar.......
my '91 track day CRX does all the time
both have IRS......
DX3Yz71lPjKSO8YfAs9qc4j8up5JsUuqrbRaHIq8EzY0wIE8uHJ1IqO6OQGOWCGl
