ArthurDent
ArthurDent HalfDork
11/4/12 11:30 a.m.
The TR7 was a bit on the rough side. The rims were nice enough but the engine was probably the best bit of it.
They were SD1 3500s. He used to have a 5spd but must have got sold a while back. Both still had fuel injection too. One was 1980 and one was a late 1982 model.
VonSmallhausen
VonSmallhausen Reader
11/4/12 1:22 p.m.
I want those rovers, both of them.
DeadSkunk
DeadSkunk Dork
11/4/12 2:33 p.m.
wspohn wrote:
DeadSkunk wrote: The Vanguard !! Station wagons are cool, and that one has a motor from a friggin' tractor. Many engine parts available from your local Massey-Ferguson dealer. Sheet metal is so thick you can stick weld patches on it. If it's a three-on-the-tree it will start from a stop in high gear.
Common misconception. The Standard wet sleeve engine was never used in Massey anything - Harry Ferguson had them install it in a small British built tractor model for a couple of years after which they switched to another power plant, so some tractors could be said to have a Standard engine, not the other way around. They also used the TR engine in various versions in boats and commercial vehicles. If you need engine parts, you look for Triumph as that is the most common application, and early cars like the Vanguard can be converted all the way upo to TR-4 engine spec (although the brakes are then woefully inadequate).
I knew the engine was a kissing cousin to the Triumph engine. My mistake was assuming that the Ferguson tractor engine was from the same family. I'm pretty sure that the triple valve springs in my father's Vanguard were replaced with ones sourced from the local tractor dealer after a farmer friend looked under the hood and wondered aloud why we had gone to the trouble of putting a tractor motor in the car. He was the one who sent us to the tractor dealership for the parts. Maybe just a lucky happenstance that they worked.
ffLB1jtcWa3Y5pxPHgZx170NLE3xDI4Zg4s7F36ZBYXctGReizMJdIFTJazh62Mu
