Didn't someone on here have an Impulse rallycross car that baffled the E36 M3 out of them until they unloaded it?
I think that was a 2nd gen (Geo Storm platform). but I do remember way back reading about a rwd rally Impulse that was mostly stock & kicked some ass. this guy:
I am, however, a former of a p'up. It was a very basic '86 model 1.8, 4 speed.
That is the same basic engine as the Impulse.
not quite. that is a GZ engine, as was the 2.0 non-turbo pre 88 Impulse. definitely direct lineage w/some parts in common but not exactly the same. turbo 2.0 = 4ZC1T, 2.3 = 4ZD1, 2.6 = 4ZE1.
I see no reason that you couldn't bolt a truck 5 speed in, and rock out.
They are the same transmission - MSG5, however the trucks are cable clutch & the Impulse uses hydraulic. they don't have removable bellhousings but the entire front half of the case comes off and once you have an Impulse box/case you can swap them onto the truck trans and have all the provisions for hydraulic slave.
As for Chevette, yes it is based on the global GM T platform. Saying the Impulse is just a Chevette is the same as saying a Fiero is a Chevettte. The upper control arm, upper balljoint, bushings, & shock is about all that is the same. lower arms use a strut/torsion rod that goes to subframes(51781) tied to each other & mounted to chassis under the rad. not the same.
so Kafka-esque mechanically in how everything was in everything else's way.
aren't all compact Japanese cars like this? cruise control & factory EBC system for the turbo added to clutter but all that crap can be binned. heads come off no different than any other I4. 2 or 3 long studs prevent the lower intake manifold from sliding straight out but you just double nut them and unthread from the head. or just pull it off in 1 piece... not sure how that is a problem?
a trooper head has larger cc and would make such low compression it would be undrivable. never heard that as an "upgrade".
it uses a Hitachi hotwire MAF. 93-95 EFI trucks used a larger housing matched to higher flow injectors. however the injectors changed to high impedance so can't use. Toyota 22RTE injectors are low-z and about same flow. I'm running 4 360cc injectors from a 3000GT 6G72T with the large Isuzu MAF & the 88-89 ecu controls it just fine along with .6 liter of extra displacement from the 4ZE1. only up to 13psi at this point but log everything on a ZT-2 it it looks just peachy.
fuel pumps are same as Nissan 240SX, I installed an Aeromotive Stealth 340 that is listed as a 240SX application. the optical distributors are very similar to the Nissans too.
this makes me miss Curmudgeon, he was the only other dude on here w/Isuzu knowledge.
