earlybroncoguy1 said:
Every "engineer" should be required to, as part of the final pre-production sign-off on a design/feasibility study/prototype, disassemble the equipment to the point a part that has failed can be replaced, replace it, reassemble the equipment, and return it to service.
By themselves. With hand tools. In cramped, dim, loud, un-climate controlled conditions. With the end user hanging over their shoulder offering advice, while their phone rings constantly. Late on a Friday afternoon before a holiday weekend.
If, after completing this task, they still think it's a good design, go ahead and put it into production.
I agree 100%
In my former career as an industrial instrumentation & controls technician (fancy name for an electrician that keeps processes processing) I used to say that the electrical engineer (and/or designer, sometimes one in the same) should have a voltage/current device connected to their chair. That way when they unintentionally design a short circuit, they get a little jolt themselves. A sort of quality control measure, as they go.
J.G., a very good article!
For the past decade and a half, I stay at home and play with cars. I'm not retired despite being old enough to qualify. Around 2004, the BMW M Rdstr my wife and I were autocrossing broke a spot-weld where the trunk floor and xmbr supporting the rearmost differential mount attach, spawning an engineering solution that I continue to produce to this day. My fabrication talent isn't the ability to imagine something that doesn't exist, as much as it is to see something that doesn't work and make corrections to someone else's design (as stated above, follow the leader).
When I come across something I need to complete a task, like some obscure tool to get something apart, or put back together, twenty minutes (or multiples thereof) with a lathe, mill and/or welder, to keep the project on track, THAT is a real joy! I've got a drawer full of essentially one-purpose tools, like this little modified socket to tighten up loose door handles on BMWs...
Or the fixtures I made to check alignment of M Rdstr/Coupe suspension carriers and trailing arms. The need here was to make a determination IF installing adjustable toe & camber kits could correct a misalignment issue, or if the (intentionally "soft") components had to be replaced. A good thing to know BEFORE wasting the time and materials (that someone else would be paying for...)!
LH shown, I also made a RH side (using brand new trailing arms and subframe for test & fabrication)
After fabrication and testing, coated with some leftover Brooklands Green MGB paint
