We are moving forward!
Cut to the money shot: white door panels are the way.
Details. I painted the panels in a semi-gloss white. It's not a fantastic paint job but hey, I forgot to put reducer in the white paint on the tub so we have a low bar here. I added a bit of Thermo-Tec Cool-It (the same stuff that's on the tunnel) to a couple of spots on the back of the panel and also attached it to the upper pads. This cut down on rattles and general flimsiness.
The stock door panels are made of masonite or something with a padded vinyl cover. This means they're a lot thicker than whatever that aluminum I bought was - I forget the gauge, but it's something like 0.020". So all the various door bits and pieces had a gap behind them. This meant I needed some sort of washer-like things. I drew them out between coats of white paint and cut a few prototypes out of hardboard on the laser. But I have a shelf full of acrylic...
As it turns out, I needed 6mm of spacer and that's 3mm acrylic. So this happened.
Too much? Maybe. I can always cut it out of black. We'll see how much it makes me smile.
I disassembled the dash and gave it a quick scuff.
This dashboard has had a long, hard life - first in a car that was left to sit outside, demolished, then chopped up and used in the race car for 12 years or so including multuple installations and removals through a cage. Here's the donor in 2003 after sitting outside in this condition for 5 years.
Anyhow...hosed it down with semi-gloss black. And I had some tiger stripes. So I took the sheen off with a light scotchbrite rub and called it good. Reassembled and hooked everything up. And decided I liked the light under the dash that I'd used for photos earlier, so I added a white LED to the underside of the dash, aimed forwards so it was diffuse. It's switched with the ignition and really makes the interior look roomy.
I do have a new gauge hood on order. This one, again, has seen much abuse and suffered the ravages of time. It's not really attached at the front. I believe it also came out of that 1991 parts car.
The final result!
Miata nerds may notice the mix of door panel parts - speaker covers from a 1.6, but pulls from a later car. That's on purpose :) The glow on the gauges is from the oil pressure light.
Dropped the hardtop back on to take a look and I have to say I'm happy. The interior suits the exterior. It's nice enough to be inviting but it's clearly all business. I may still do something about the center tunnel, but not immediately.
So that wraps up most of the work. I'll start playing with that gauge cluster more now, so you're not all off the hook yet.
For those who are into those video things, I'm doing a FB Live presentation on the car at 2:00 PM Mountain on Jan 14th. That's tomorrow as I write this, your personal calendar may vary :) You can ask questions and listen to me ramble on about whatever crosses my mind. Bonus points if someone manages to get me talking about pressure differentials.
