xFactor
xFactor Reader
1/17/15 7:07 a.m.
http://www.redpepperracing.com/forums/index.php?showtopic=54670&view=&hl=&fromsearch=1
My crx itb project, lots of pics.
Matt
RossD
RossD PowerDork
1/17/15 10:12 a.m.
You need a non linear opening mechanism to help with the just off idle throttle actuation. Almost logarithmic.
turboswede
turboswede UltimaDork
1/17/15 5:04 p.m.
RossD wrote: You need a non linear opening mechanism to help with the just off idle throttle actuation. Almost logarithmic.
Yeah, I built my own bell crank for the throttle shaft on my TWM's. It did help a bit, but ultimately the 45's were just a bit too big for a SOHC 2.0L with 8.5:1 compression and a bigger cam.
Adding the Franco automatically adjusting timing gear help flatten the power curve with that lumpy cam. Set it to -3 degrees from idle to 3500 and then it switches to +7 degrees like a mechanical advance distributor. Cool old school hot rod tech.
turboswede
1/17/15 5:11 p.m.
Here's some pics of the Tuned intake I built for the TWM ITB's along with the throttle cam (needs less offset for the initial pedal throw.)
OR1oQcU19nLmh7r2f0qjqp8lrve3MGsCM3eEirTW1DHF9npb0eTLpl68h7recBYE
