11/15/13 12:57 p.m.
I had this problem at lunch today where I'm driving along, and from the back of the Sammy I get this horrific grinding, scraping noise that cycles at wheel speed. With each awful scrape the vehicle decelerates a bit. When the noise happens the handbrake feels tighter. It lasts for a few seconds while driving and randomly reappears. Rocks in the wheel drum right?
mndsm
mndsm UltimaDork
11/15/13 12:58 p.m.
That'd be my guess.
Streetwiseguy
Streetwiseguy UberDork
11/15/13 1:02 p.m.
Or the friction material on the shoe has come unbounded. Worth a look.
ultraclyde
ultraclyde SuperDork
11/15/13 1:03 p.m.
..or parts of the drum brakes. BTDT....
11/15/13 1:12 p.m.
Shoes are brand new, hope they're still good because they replaced another set of new shoes that were ruined by a brake fluid leak.
Wayslow
Wayslow Reader
11/15/13 1:17 p.m.
I've had brand new brake shoes come apart on me and cause the same symptoms you're describing. Of course I've been driving British cars for years so I've also had springs, adjusters and emergency cables break inside the drum and cause the same issues.
oldeskewltoy
oldeskewltoy Dork
11/15/13 1:20 p.m.
open and inspect.... might be stones, pebbles... also could be broken bits of hardware...
11/15/13 1:52 p.m.
That's what I gotta do tonight...
The0retical
The0retical HalfDork
11/15/13 3:11 p.m.
Streetwiseguy wrote: Or the friction material on the shoe has come unbounded. Worth a look.
I had that happen except pretty much the way described. It really sucked when the other one let loose on the way home and the pedal went to the floor on Clyde Morris Blvd...
Toyman01
Toyman01 UltimaDork
11/15/13 3:28 p.m.
On drums, I would bet a broken spring. On disks, I would bet a rock.
airwerks
airwerks New Reader
11/15/13 4:38 p.m.
I had a Samurai, with the exact same symptoms. Pulled it apart and it was busted ebrake retaining hardware.
Aeromoto
Aeromoto Dork
11/15/13 5:50 p.m.
Axle bearings
wbjones
wbjones PowerDork
11/15/13 6:53 p.m.
guess there are more than one Clyde Morris Blvd … your profile says CA … the one I'm familiar with is in Daytona … ol Clyde must be more famous than I knew ...
The0retical
11/16/13 1:10 a.m.
I attended school at ERAU Daytona (also where I discovered GRM in the library). I suppose a state would have helped but anyone familiar with Daytona International Speedway knows what I'm talking about
Jaxmadine
Jaxmadine HalfDork
11/16/13 7:48 a.m.
Your hardware broke. Stop driving before u need shoes again
wbjones
wbjones PowerDork
11/16/13 9:56 a.m.
The0retical wrote: I attended school at ERAU Daytona (also where I discovered GRM in the library). I suppose a state would have helped but anyone familiar with Daytona International Speedway knows what I'm talking about
not from Fla, but I'm familiar with Clyde Morris Blvd … it's my way out of town after the Rolex, instead of trying to make a left out of the track parking and then the hr+ wait to get on I 95 … plus there's a Shell (which I use most of the time) at the intersection where I get on the interstate …
I was just wondering if there was a CMB in CA
poopshovel
poopshovel MegaDork
11/16/13 10:27 a.m.
Stranger things have happened. I came into a turn a little hot on the way home last week and "hit the berm" to scrub speed/push through the turn. Rear passenger wheel went into a big gravel-hole, and immediately the brakes on that wheel (disc) started making horrific noise. Has happened a couple times since then. I need to pull the wheel this weekend and take a look.
DBxERuzh6AGxiuDNSB8vIa7xUmkfjOwuo2vM2oCPR2jOUc680lNdSyJLUa5h41vh
