Fitzauto
Fitzauto HalfDork
3/4/16 4:00 p.m.
So I have my new balljoints in and tightened and then it comes time to re-attach the tie rod to the knuckle. The nut keeps spinning along with the stud. Should I try putting a jack under it to add pressure and get the taper to seat right?
WildScotsRacing
WildScotsRacing Reader
3/4/16 4:48 p.m.
That has worked for me on more than one occasion
Dusterbd13
Dusterbd13 UberDork
3/4/16 4:50 p.m.
I've also smacked the E36 M3 out of them with a 3lb hammer to get the taper to seat.
BrokenYugo
BrokenYugo UltimaDork
3/4/16 4:56 p.m.
Shouldn't take much to get it seated, make sure the tapers are clean. EDIT: I like to pull a clean rag through the hole.
erohslc
erohslc Dork
3/4/16 4:58 p.m.
Loctite Red on the taper.
Might not even need the nut.
OK, OK, just kidding ...
Fitzauto
Fitzauto HalfDork
3/4/16 4:59 p.m.
Thanks. Hopefully cant get it all buttoned up before tomorrow's track day.
Vigo PowerDork
3/4/16 5:49 p.m.
I usually get a pair of hands to help me out by squeezing the two parts together with a big set of channellocks. If i'm by myself id have to try something like the jack to put a load on the tapered joint.
aircooled
aircooled MegaDork
3/4/16 7:09 p.m.
Yes, grab pretty much anything you got from Harbor Freight more then 6 months ago and smack away!
84FSP
84FSP HalfDork
3/4/16 7:29 p.m.
Hitting it with an impact seems to work ok as well.
outasite
outasite Reader
3/5/16 8:56 p.m.
Longish pry bar to provide force, clean both surfaces, clean threads on nut and stud.
Jerry From LA
Jerry From LA Dork
3/5/16 9:13 p.m.
A large-enough vise grips works if no one else is around.
carzan
carzan Dork
3/6/16 8:40 a.m.
I fought this battle not long ago until I realized it was made where you could put an allen wrench in the end of the stud and hold the stud with the allen wrench while turning the nut with an open end wrench. Don't know what brands do this, but it makes it soooo much easier.
chiodos
chiodos Dork
3/6/16 10:54 a.m.
Others have flats cut into the top (fat end of the taper) that's sometimes hidden under the rubber boot. Come to think of it I haven't seen many that don't have either the flats or something machined in to hold the stud.
Fitzauto
Fitzauto HalfDork
3/6/16 10:58 a.m.
Used the jack trick and that worked.
b8jyvBg8VhzOxio4BERXxiSn55JCCKY5hlSZkyEUEMamtLDyAkmUxpKFG43bszWL
