Craigorypeck
Craigorypeck New Reader
10/24/17 9:22 p.m.
Throwing together a ford 2.3 turbo.
1st 2nd 4th 5th bearings measure between 0.0020 - 0.0026
3rd middle thrust bearing coming in at 0.0015
I can source a +0.001 thrust bearing to gimme 0.0025
No budget left for anymore machine shop work. All the crappy used components I bought needed repaired so funds are limited.
Should work, eh?
Knurled
Knurled MegaDork
10/24/17 9:26 p.m.
Soak some emery paper in carb cleaner or kerosene or something and then rub it against itself to "kill" it, then clean some of the overlay off of the bearings?
Old Mazda Rotary method of making high clearance race bearings out of stockers.  The overlay in the stock bearings in those was about .0005" thick so sanding it completely down to the copper would add .001" clearance.  Overlay is only there to embed garbage, some people would rather have the garbage floating in the oil than have it embed and continue graunching away at the crankshaft...
Craigorypeck
10/25/17 8:19 a.m.
I rather not modify the bearings if I could avoid it to be honest.
curtis73
curtis73 PowerDork
10/25/17 9:24 a.m.
Start it up without oil for a few minutes?
(seriously though, don't do that)
volvoclearinghouse
volvoclearinghouse UltraDork
10/25/17 9:49 a.m.
At the last LeMons race, the oil pump pickup fell off and the car made a full lap (2 miles) on a 460 Ford turning 2000-3000 RPM with 0 oil pressure.  Fixed the pickup, started the engine up, and it ran great and seemed to have even more power.  We joked that we'd opened up the bearings to "race tolerances".
We also run Mobil1 15W-50.  So even with 0 pressure, there was probably a good bit of residual lubrication available.
jimbbski
jimbbski Dork
10/25/17 11:26 a.m.
I would try to "polish" the #3 crank journal to open the clearence up a bit. Take some 1 inch wide emery cloth and treat that journal like an old shoe.
APEowner
APEowner HalfDork
10/25/17 2:25 p.m.
Yes, a +0.001 bearing will do what you're after.  If it turns out that you end up with too much clearance you can run one std and one oversize shell although I don't really like to do that with main bearings.  You can also try another std bearing from another manufacturer.
iceracer
iceracer UltimaDork
10/25/17 6:40 p.m.
Chilton says:  .0008 to .0024
Craigorypeck
10/25/17 7:21 p.m.
Got some +.001 So I'll throw those in.
Jerry From LA
Jerry From LA SuperDork
10/25/17 7:30 p.m.
I'd leave it and assure myself of better oil pressure at the end of the crank furthest from the oil feed.  Also, I would turn the crank 90 degrees and measure all the bearings again at the same spot.  Could be a slight bend in the crank.
Craigorypeck
10/26/17 7:53 a.m.
Measuring was done at shop with bearings only installed.
Jerry From LA
10/26/17 12:08 p.m.
If your machine shop does its own crank work, they can micropolish that journal a little more and get you to .002." Otherwise, I'd leave it alone.
bentwrench
bentwrench Dork
10/26/17 5:19 p.m.
ScotchBrite the bearing shell to open it up.
You need to make sure your crank is not bent.
Rotate the crank 180° and remeasure.
Craigorypeck
10/26/17 5:20 p.m.
I'm gonna lean hard on this... if it weren't the middle thrust bearing I would leave it too Jerry
Craigorypeck
10/26/17 5:24 p.m.
I read the faq on the bearing suppliers website and it said under no circumstances should the bearing be modified. A rub with newspaper was all that was permitted! I was gonna email and see what they thought about sanding the rear of the bearing.  Lol
RealMiniParker
RealMiniParker UberDork
10/27/17 10:48 a.m.
Please clarify. You keep saying "thrust bearing" - flat pieces that take up end-play in block/ crank relationship.
Are the suggestions given so far, for that? Or, is everyone misunderstanding you, and talking about journal bearings?
RealMiniParker
10/27/17 10:58 a.m.
So .0015 should be just about as middle of the tolerance, eh? wink
gearheadE30
gearheadE30 HalfDork
10/27/17 11:07 a.m.
Don't sand the rear of the bearing. Changing the OD could dramatically increase the risk of spinning the bearing.
Craigorypeck
10/27/17 2:21 p.m.
On this particular engine the middle main bearing is also the thrust bearing..
Craigorypeck
10/27/17 2:25 p.m.
I was kinda joking there
RealMiniParker
10/27/17 10:22 p.m.
In reply to Craigorypeck :
Gotcha. After posting that, the combined thrust/journal bearing idea came to me.
oRB3DcEaFjd1F94CoBpY5XHA75SjzcKgcvr9Fiti2feRS4YJmfzViyZltuZkJNN0
