Knurled
Knurled Dork
2/11/12 4:05 p.m.
A comment in the Stealth thread got me to thinking.
Have there been any timing belt engines designed in the last 25 years that do NOT drive the water pump off of said belt?
The only one I can think of is the Mazda K-series V6.
mad_machine
mad_machine SuperDork
2/11/12 4:11 p.m.
Hyundai's Alpha and Beta range of engines have a seperate belt for the alternator and other pumps
novaderrik
novaderrik SuperDork
2/11/12 4:17 p.m.
i think that the DOHC 3.4 that was put in a lot of GM cars in the 90's drove the water pump off the accessory belt, but i don't know it that fits your criteria because it's a DOHC version of the 60 degree V6 that came out in the very early 80's.
Streetwiseguy
Streetwiseguy SuperDork
2/11/12 4:47 p.m.
I was going to write a big long list, but then I started thinkin...
4g63t
4g63t HalfDork
2/11/12 4:56 p.m.
4g63 drives the water pump from the accessory belt.
HappyJack
HappyJack Reader
2/11/12 4:58 p.m.
GM 2.2 in the Cavaliers and Sunfires.
Hey, you didn't say good engines.
iceracer
iceracer SuperDork
2/11/12 4:58 p.m.
Zetec
belteshazzar
belteshazzar SuperDork
2/11/12 5:11 p.m.
HappyJack wrote: GM 2.2 in the Cavaliers and Sunfires. Hey, you didn't say good engines.
don't have a timing belt
Hocrest
Hocrest HalfDork
2/11/12 5:25 p.m.
Subaru from the 80's and early 90's.
EA82 and EA82 turbo in all the box shaped wagons ER27 in the XT6
HappyAndy
HappyAndy HalfDork
2/11/12 6:16 p.m.
The Suzuki engine used in the X90 and Side Kick is SOHC w a belt & doesn't drive the WP from it. IDK if that makes the designed in the last 25 years stipulation or not.
Ian F
Ian F SuperDork
2/11/12 7:22 p.m.
The R53 MINI drives the water pump off the tail end of the supercharger... not that this is always a good thing since the gear box in the SC is hard to access and you often don't know the oil has leaked out until it's too late.
The R50 drives it off the standard belt (the Tritec base has a chain).
HappyJack
HappyJack Reader
2/11/12 8:29 p.m.
Doh! Now I feel stupid. I knew that.
Curmudgeon
Curmudgeon SuperDork
2/11/12 8:35 p.m.
Well, the Chrysler 2.7 runs the water pump off the timing chain. Technically that's not a belt.
92CelicaHalfTrac
92CelicaHalfTrac SuperDork
2/11/12 8:40 p.m.
Knurled wrote: A comment in the Stealth thread got me to thinking. Have there been any timing belt engines designed in the last 25 years that do NOT drive the water pump off of said belt? The only one I can think of is the Mazda K-series V6.
Pushing it on the age, but the 1.8 BP in my escort wasn't driven off timing belt either.
F2T isn't either.
EvanB
EvanB SuperDork
2/11/12 8:56 p.m.
miata is always the answer.
Strizzo
Strizzo SuperDork
2/11/12 10:18 p.m.
F2t is driven off the tbelt
Pbw
Pbw New Reader
2/11/12 10:44 p.m.
Zetec 2.0 runs off accessory belt, heck you can take the entire pump off without removing anything timing belt related.
92CelicaHalfTrac
2/11/12 10:48 p.m.
Strizzo wrote: F2t is driven off the tbelt
Yeah I got mixed up. Forgot I only had two belts on mine. Tbelt and alternator.
sergio
sergio New Reader
2/11/12 11:16 p.m.
3.0 and 3.2 SHO engines.
novaderrik
2/11/12 11:28 p.m.
the 2.2 Ecotec uses a separate chain under the timing cover to run the water pump, but it also uses a timing chain to run the cams so it's also irrelevant to this discussion.
mistanfo
mistanfo SuperDork
2/11/12 11:31 p.m.
I do wish that the Miata WP could be swapped without having to pull the timing belt, even though it is driven by it's own belt.
Fit_Is_Slo
Fit_Is_Slo Reader
2/12/12 12:04 a.m.
Toyota/Lexus 2JZ
noddaz
noddaz Reader
2/12/12 11:29 a.m.
VW 1.8 and 2.0s...
Knurled
Knurled Dork
2/12/12 2:13 p.m.
iceracer wrote: Zetec
Really? The CVH drives it off of the timing belt, I would've thought that the Zetec would do that too, since it's pretty much the same engine. OTOH I guess I never paid much attention. People with Zetec engined cars tend to just use them until they break and then throw them away.
I wasn't counting Mazda B-engines or VW engines since they were designed in the 70s... and the VW 06A block update has a timing belt driven water pump. Looks almost like the Audi fives, it does... except VW put an actual belt tensioner on it, instead of putting slotted holes on the water pump for tension adjustment.
And then putting the water pump behind a metal inner timing cover, turning what should be a 2 hour job into a much longer ordeal.
Ranger50
Ranger50 Dork
2/12/12 3:36 p.m.
Knurled wrote: I wasn't counting Mazda B-engines or VW engines since they were designed in the 70s...
Same with 2.0/2.3/2.5 Fords.....
ZyAKiludFWWCtEBQn5ssnwXjVybP8zGiUKaKdAIWaMP1D7ceFUzxoqKolNH20VHf
