stan_d
stan_d Dork
5/25/12 2:59 p.m.
How much is enough on the inner sidewall and the spring perch ? The camber adjustment is at top of strut.
3/8" spacer gives me a 1/4 "
JohnInKansas
JohnInKansas Reader
5/25/12 3:51 p.m.
I suspect it depends on the car, what you're doing with it, height of sidewall, etc. Beyond that, I dunno.
I'm interested though.
fast_eddie_72
fast_eddie_72 SuperDork
5/25/12 4:23 p.m.
On the Celica, it's barely anything at all. You couldn't slip a credit card btween the wheel and the coil over perch. I ground it back a little, but I don't think it's a 1/4". I have run stock wheels with race rubber on my MR2. With no spacer, they rub on the first couple of runs. Then they're fine. Not optimal, but, you know.
iceracer
iceracer UltraDork
5/25/12 5:05 p.m.
On my ZX2SR the rears had a clearance of a piece of cardboard, ie: not much. No problm with rubbing. Never had a problem with the front.
Vigo SuperDork
5/25/12 5:45 p.m.
Yeah, you need VERY little. The tire may deform laterally at the bottom but by the time it spins to the top it's centered again, so you dont need much there at all.
MichaelYount
MichaelYount New Reader
5/25/12 5:48 p.m.
As long as it's a classic MacPherson strut -- the position of the tire never changes relative to that part of the strut. As others have said - a miss is as good as a mile. On my old Corolla ITB car I actually slightly dimpled the insert housing to create a credit card's worth of clearance. Raced it that way for 9 seasons with never an issue.
GameboyRMH UberDork
5/25/12 6:23 p.m.
On the rear of my AE92 with coilovers, it's about 4mm, I've run many events like this, no problems. Some people get shorter springs on the rear so they can run wider tires on these things.
tr8todd
tr8todd Reader
5/25/12 6:36 p.m.
When I'm building coil overs, I always make sure the perch is above the tire to give me maximum clearance. That being said, 1/4 sounds good. The tire shouldn't flex inwards at the top. Bad wheel bearings could cause a problem thou.
Giant Purple Snorklewacker
Giant Purple Snorklewacker UltimaDork
5/25/12 7:15 p.m.
I clicked on this, based on the title, expecting a sale on slicks. That tells you where my head is at this weekend...
mad_machine
mad_machine MegaDork
5/25/12 8:43 p.m.
Giant Purple Snorklewacker wrote: I clicked on this, based on the title, expecting a sale on slicks. That tells you where my head is at this weekend...
Don't feel too bad.. I thought the same.. and I don't need any new tyres. (my mom's rendezvouz does though)
fast_eddie_72
5/25/12 9:11 p.m.
Celica wheels before I mounted tires. Yeah. It's close.
As I said, I did grind that mount back a tic, but it's still really close. Seems to be fine.
z31maniac
z31maniac UberDork
5/25/12 10:29 p.m.
Many talking.g about wheels when he asked about tires. As long as the tires aren't rubbing under load I wouldn't worry about it.
For the wheel, 1/4" is probably the least I'd feel comfortable with.
stan_d
stan_d Dork
5/26/12 1:54 p.m.
The wheel is fine just the tire is close. 205 fits fine I want 235
ywe99JFJ50BGPwpI3U6KLmMHX8zmd6XypYGe8HmPvAbhtBpBvfdt3rkTWfP120c1
