Mazdax605
Mazdax605 PowerDork
8/8/20 7:37 p.m.
Hey guys,
About 2-3 days ago my 06 Sienna started with a dull vibration that seems suspension related. I say that because when I drive on the freshly paved main road around the corner from where I live I don't feel or hear anything, but on any other road I am hearing/feeling something. It sounds like it's coming from the right front according to my ears and my 14 year old son as well. However I'm feeling it around the tunnel/accelerator pedal area as well. How do you guys go about trying to figure out weird vibrations/sounds? It's very dull and slight, but it's there. The car has 190k on the clock and everything in the suspension is factory original.
1988RedT2
1988RedT2 MegaDork
8/8/20 8:51 p.m.
CV joint?  Wheel bearing?  Jack up the front end and check for play?  How are the tires?
Drive it 'til it gets worse?
Mazdax605
Mazdax605 PowerDork
8/8/20 8:54 p.m.
Tires are probably 2 years old, but only used between May and December. It's really an odd vibration, I can't figure out where it's coming from when driving it, but it does seem to be coming from the front.
TurnerX19
TurnerX19 SuperDork
8/8/20 8:55 p.m.
Check all the engine and trans mounts too.
Vigo (Forum Supporter)
Vigo (Forum Supporter) MegaDork
8/8/20 11:25 p.m.
I'd guess wheel bearing as most likely in a long list of possibilities. Does the noise change when swerving back and forth?
Fueled by Caffeine
Fueled by Caffeine MegaDork
8/9/20 8:07 a.m.
at about that mileage I had a very odd vibration and a clunk from the front end. Was a collapsed strut.
04 sienna.
Mazdax605
Mazdax605 PowerDork
8/9/20 8:31 a.m.
It does not change with swerving.
8/9/20 10:01 a.m.
Well, might have to put the control arms on jack stands (so its at ride height, but off the ground) and get under there while someone manages the throttle. Possibilities are wheel bearings, CV axle center support bearing, differential side bearings, or just a general graininess coming through a failing engine mount. Hard to say without feeling it. If you don't find anything and the tires are not directional switch them side to side so they both spin the other direction and see if it changes.
Mazdax605
Mazdax605 PowerDork
8/11/20 5:20 p.m.
Blown strut?
Jesse Ransom
Jesse Ransom UltimaDork
8/11/20 5:26 p.m.
In reply to Mazdax605 :
I was wondering...
"Doesn't do it on glassy smooth but does on anything rougher" does sound a bit like the system is lacking a damping element. I would not have bet any money on it 'til I saw your pic, though.
Mazdax605
Mazdax605 PowerDork
8/11/20 5:29 p.m.
I was wondering...
So, yes, blown strut?
Mazdax605
Mazdax605 PowerDork
8/11/20 8:59 p.m.
OEM replacements, or aftermarket? I'm thinking about complete struts with springs and all.
Tyler H (Forum Supporter)
Tyler H (Forum Supporter) UberDork
8/12/20 9:18 a.m.
Strut tops / bearings are probably ready, too.  If you can get a full assembly for a reasonable price, I would do it.  Probably won't need PB Blaster on the strut knuckle on that side.  :)  I wouldn't do OE.  Check your swaybar endlinks, bushings, and balljoints before you start ordering parts.
Mazdax605
Mazdax605 PowerDork
8/12/20 9:20 a.m.
Yeah, was thinking of replacing the entire strut assembly with the springs and everything. Any particular brand better than others? OEM would be a good choice but they're pricey.
Fueled by Caffeine
8/12/20 10:23 a.m.
I put the highest quality quick struts I could find on the car.  I think I put kyb's on there rock auto has them. Monroe is 2nd choice.  I guess it depends on how long you want to keep the car.
I knew it was a strut. Sounded just like our old. Sienna. Same mileage as well
CAinCA
CAinCA Reader
8/12/20 12:10 p.m.
Our 05 with around 190k on it had a vibration under load and at highway speeds. I had a mechanic that I trusted take a look at and he couldn't find anything. I finally told him to replace both axles. He initially refused saying he didn't want to waste my money. I took him on a drive and showed him the issue. He told me that I drove it much harder than he did but now he could feel it. He swapped in the new axles and it was like new.
We put a set of the Monroe quick struts on my son's Mazda 3. It was easier that I thought it would be. It cuts out about half the work and the most dangerous part of the job.
Mazdax605
Mazdax605 PowerDork
8/12/20 6:34 p.m.
So I've heard lots of people saying Monroe is a good choice, but a few people saying that they're terrible. I don't know what to think now.
Streetwiseguy
Streetwiseguy MegaDork
8/12/20 7:33 p.m.
What is the alternative to Monroe?  I've installed a boatload of their OESpectrum or whatever the hell they call them, and have had zero trouble.  Monroe-Matics are cheap junk.
Remember, you are not competing with a set of Penske's on your late model, here.  You are looking for struts for your wifes minivan.
Mazdax605
Mazdax605 PowerDork
8/12/20 7:35 p.m.
My minivan!
8/13/20 1:14 a.m.
I've installed the cheapest quick struts known to man on a whole bunch of vehicles. They all work ok but just seem to fall off quicker than oem-quality stuff, as in they feel noticeably different within 20k miles instead of the 60-150k I see from oem dampers before they become objectionable. That may or may not matter depending on how many miles you put on this thing.
Mazdax605
Mazdax605 PowerDork
8/13/20 8:36 a.m.
The reality is that while it's not a very cool vehicle I absolutely love this thing. I keep thinking about replacing it because I'd like to get something cooler as a daily driver, but you really can't beat a minivan when it comes to versatility. It has 190k on it, and I'd like to get as many years as possible out of it because the budget won't really allow for two car payments and my wife got a new car last year.
I went to my friendly local Napa and they want $250 a piece for fully loaded struts. In my searching I have come to realize there is a difference in the 7 and 8 passenger model struts. Of course we have the 8 passenger one. I wonder what the difference is, weight load, higher spring rate?
Mazdax605
Mazdax605 PowerDork
8/14/20 11:06 a.m.
Ordered new Monroe quick struts from Rock Auto yesterday around 2PM. Got an email saying they would be delivered on Tuesday August 18th. This morning around 11AM I get an email saying they've been delivered. Think, no way that is true. Go home for lunch because I was nearby. Sure enough there is a huge box on my porch with RA stickers on it. I can't believe this!!
CAinCA
CAinCA Reader
8/14/20 1:09 p.m.
Honestly, my wife and I were anti mini-van before we had kids. Then when #1 came along and we tried to use the club cab truck with suicide rear doors as the baby carrier it became apparent that a mini-van would be much more useful. We put 200k on ours before we sold it. I put 135k of those on it after she was done with it and wanted an SUV. I'm sure it will go another 100k. The only issue it had was one of the rear power doors quit working. I turned the master switch off after the dealer told me it'd be $1500 or something to fix it.
Mazdax605
Mazdax605 PowerDork
8/14/20 1:35 p.m.
I've never replaced struts before. Is it as straight forward as it seems? Two big bolts on the bottom, a few brackets that hold the brake line, and ABS wiring, and the 3 nuts on the top?
Mazdax605
Mazdax605 PowerDork
8/14/20 9:05 p.m.
Okay, so I changed the bad passenger side strut out. Of course the sway bar end links had to be cut off and now I need to go buy new ones tomorrow morning. The strut replacement was actually pretty easy, but that sway bar end link was a total nightmare. I hate living in the rust belt!!
JmUhKgn8Erk7U7sxdJQ8BasFMxexPeP3NhrJ2KegGzWFOtd00wGx07dFQrHj8Z28
