GTwannaB
GTwannaB New Reader
4/28/10 4:44 p.m.
My never ending car search is plagued by my nitpicking need to find a car with or without specific options. I have been looking at MK3 VWs and Focus SVTs both of which sometimes come with traction control. I would like to avoid the nanny factor of traction control but I do not know if I am being overly picky. Has anyone driven a traction control equipped SVT Focus or VR6 GTI in anger? Is it really intrusive or is it hardly noticeable? The car will see rain, but never snow.
irish44j
irish44j HalfDork
4/28/10 4:53 p.m.
Don't they have VDC/TC disable buttons?
Tommy Suddard
Tommy Suddard SonDork
4/28/10 5:11 p.m.
What he said^
Traction Control is the sukz.
irish44j
irish44j HalfDork
4/28/10 5:17 p.m.
And if no disable button, just do like we did on the 4Runner this winter: pull the plug under the hood
billy3esq
billy3esq SuperDork
4/28/10 5:58 p.m.
My Focus SVT didn't have it, but I believe it can be disabled (switch on either the dash or console).
IIRC, only the EAP/Cold Weather package cars had it. Most did not.
Grtechguy
Grtechguy SuperDork
4/28/10 6:42 p.m.
I live in the snow belt, I disable the TC. why? because occasionally, you NEED to spin the wheels to rock the car out of the snow. With the TC on, you're stuck if its heavy wet snow or slush. I see it over and over again.
PS. the disable switch rarely completely disables the it btw. best way is to remove the ABS fuse and be done with it.
Streetwiseguy
Streetwiseguy Reader
4/28/10 6:54 p.m.
ABS and traction control work fine on clean dry pavement. The worse the road conditions, the more likely you are to die because of electonic intervention.
And if any of you don't believe me, come visit in January and I'll put you behind the wheel of an Astrovan with the early abs. The newer the vehicle, the less active the programming, it seems. Kind of like the early airbags that killed short people- the gov eventually decided to depower the bags a bit and let people live..
Nitroracer
Nitroracer Dork
4/28/10 9:14 p.m.
My focus svt had traction control, and while there was a switch to turn it off I hear it still intruded at the limit.
I ran an autocross once and left it on, I couldn't figure out why it was down on power coming out of certain corners. I realized that since the car has an open diff it was trying to spin a wheel out of tight corners and the traction control was fighting with me.
Day to day I rarely had it intervene. Then again it had a hard time turning the tires from a stop anyway.
carguy123
carguy123 SuperDork
4/28/10 9:17 p.m.
07 350Z was faster with traction/yaw control on the autocross course than without.
BobOfTheFuture
BobOfTheFuture Reader
4/28/10 10:04 p.m.
My SVT can be intrusive, but its only a fuse away, as long as you dont mind losing ABS.
A Diff helps alot on making it calm down
pilotbraden
pilotbraden New Reader
4/29/10 9:21 a.m.
I do not like traction control. Dad's G35 is faster in the snow without it. Friend's 4 door Wrangler gets stuck in bumper deep snow ( I pull him out with my 97 Nissan pick up, same size snow tires as the jeep).One reason that I bought a 2009 base model RX-8 is the lack of traction control.
GameboyRMH SuperDork
4/29/10 9:32 a.m.
Traction control = bad. Pull the fuse or flip the switch.
Hal
Hal HalfDork
4/29/10 9:49 a.m.
Traction Control on the Focus SVT can be turned off. we had a note to that effect taped to the steering wheel in this car
It can be defeated entirely but as noted pulling the fuse will also affect the ABS.
Best solution is to put a locking diferential in the car.
Giant Purple Snorklewacker
4/29/10 9:55 a.m.
IIRC all you need is aftermarket software to defeat it on the SVT.
mad_machine
mad_machine SuperDork
4/29/10 10:44 a.m.
my idea of traction control is an LSD... my BMW has it, and even with badly worn summer tyres, I was still able to drive that car through several inches of snow this winter.
get one without traction control and have a limited slip added to the diff?
AS for ABS. I will be adding a defeat switch to the saab. It steps in WAY too early
njansenv
njansenv Reader
4/29/10 11:16 a.m.
I thinked we've had this discussion before....
FWIW, I LIKED the stability control on the M3. It was relatively unintrusive unless I was misbehaving, and it added a measure of security on "surprise" surfaces.
Paul_VR6
Paul_VR6 Reader
4/29/10 11:20 a.m.
The VW would have EDL and there's no way of disabling it short of pulling an ABS sensor. Breaks axles very cleanly when it engages when you're trying to launch the car.
GTwannaB
GTwannaB New Reader
4/29/10 12:51 p.m.
Thanks, I know you can partially disble the traction control on SVT, but without pulling the ABS switch the TC will always be lurking, even with the tune. Does the VW disable switch fully disable TC?
Gearheadotaku
Gearheadotaku Dork
4/29/10 5:38 p.m.
I've driven seveal newer cars with trac control and stability control. They are all horrible. Seveal times when cornering at speed the car would "bog down" and I would lose the intended path. ABS i can live with some times, but these other systems scare me.
Paul_VR6
Paul_VR6 Reader
4/29/10 8:21 p.m.
The later VW's that have the ASR button will fully disable it when the switch is activated.
Streetwiseguy
4/29/10 8:38 p.m.
All my vehicles have had traction control, and stability control. I'm pretty sure thats what the 3 pedals on the floor and the round thing in front of you do.
The_Jed
The_Jed Reader
4/30/10 12:02 a.m.
Wiggles his foot
/Southern accent on/
"This is my traction control, sir."
/Southern accent off/
ABS too...
ignorant
ignorant SuperDork
4/30/10 5:05 a.m.
didn't grm do a story that showed that all the "nannies" can actually make you more consistent and sometimes faster.
ultraclyde
ultraclyde Reader
4/30/10 9:45 a.m.
I always run the TC on my Mustang on the street unless I'm REALLY trying to hoon it. It allows for a reasonable amount of side slip and wheel spin before intervening, but when it does, man, it DOES. I always turn it off when autocrossing since I'm in a controlled environment.
Personally, I think as long as you can turn it off it wouldn't keep me from buying a car. I also would absolutely not disable the ABS on any recent vehicle. I realize that a well trained entusiast can outbrake the ABS system and that there are conditions that negate it's effect, but other people occaisionally drive my car and I live in the south. The circumstance where it helps outweigh the circumstance where it hurts. Again, my opinion on what seems to be a touchy subject sometimes.
mad_machine
4/30/10 1:12 p.m.
exactly.. as per turning off the ABS in my saab.. it would be on for 99.9% of the driving I do... but after this winter, I realised how much faster you stop in snow when you can lock the wheels and make a snow plow out of them
SAeonit0eft1OJtI6n3MmtVd3VAys8QfhxJOshmPuu8rCFtDXsWEGliA8QG4mCgR
