stroker
stroker PowerDork
8/16/23 2:32 p.m.
Does somebody make a tube frame sand rail (or something similar) with a mid-engine layout?
gixxeropa
gixxeropa New Reader
8/16/23 2:36 p.m.
Something like a DF Goblin? not a sand rail but a tube frame mid engine kit car
stroker
stroker PowerDork
8/16/23 2:41 p.m.
Yeah, something like that might work for what I had in mind.  It's a little taller than I'd like, but it might be the straightest line from A to C.
8/16/23 2:52 p.m.
I used to see them all the time in the VW magazines, so if not available new, there may be used ones out there.
wearymicrobe
wearymicrobe PowerDork
8/16/23 3:08 p.m.
Dozens of companies used to make just this. Swap the gear in the transaxle and you are good to go. Go to thesamba and find a chassis for pennies.
buzzboy
buzzboy SuperDork
8/16/23 4:33 p.m.
In my ACVW days I saw a lot of them. Can't recall any brand names. Most use the swingaxle transmission because you can flip the transmission instead of messing with the gears.
dailyraces
dailyraces New Reader
8/17/23 12:30 a.m.
Chenowth made a sand rail frame. BITD.
Driven5
Driven5 UberDork
8/17/23 1:41 a.m.
Aren't the VW rails all designed for rear engine, rather than mid engine?
8/17/23 6:04 a.m.
In reply to Driven5 :
Not all of them.  There are mid engined rails out there.  They seem to all have longer wheelbases, which can be a plus or a minus, and they don't retain the VW rear suspension, which again can be a plus or a minus.  They tended to be more expensive because of these two things.
I'm seeing a few on eBay, but eBay is usually not a good place to buy a vehicle if you want cheap.
8/17/23 7:38 a.m.
Traditional formula car like an Atlantic or Continental?
Paul_VR6 (Forum Supporter)
Paul_VR6 (Forum Supporter) UltraDork
8/17/23 7:58 a.m.
Definitely seen some mid-engine vw rails over the years but it's gotta be 20:1 compared to rear engine. The ones I have seen usually were non vw power (v6/8 swaps usually) and had a pretty beefy trans like a mendeola, highly modded suspensions.. so quite a different market segment.
buzzboy
buzzboy SuperDork
8/17/23 8:40 a.m.
This is the suspension/trans setup I am most familiar with. It would be much cooler with trailing arms instead of swing axles.
WP8O0H82wRhXltBr4njZOT5Jl1yuf7TkOmO3QedALCkiLSjMmILC7vm8ij0OXjvK
