dyintorace
dyintorace PowerDork
1/1/23 8:15 p.m.
I bought this from HF forever ago. It is (was) a great jack. Lightweight but sturdy and jacks to a very tall height.
It recently stopped working. I assume a seal (or seals) has gone bad. Is there a relatively simple rebuild process? New jacks aren't that expensive but I'd love to rehab this one instead of pitching it and buying new. Any advice?
Looks just like this:
matthewmcl
matthewmcl Dork
1/1/23 8:38 p.m.
Make sure the oil level inside is high enough, too. I had one stop after just a month, but all it needed was to be topped up.
nocones
nocones PowerDork
1/1/23 8:48 p.m.
Mine intermittently will have one of the plungers no longer..  plunge.  Or I should say spring back from plunging.  This renders the jack hopelessly useluess until I pull the plunger appart and clean it.  I'm not sure where all the metal and dirt and crap that gets into the plunger comes from.
Oapfu
Oapfu Reader
1/2/23 12:55 a.m.
1/2/23 2:05 a.m.
Mine is coming up on five years old, guess I should check the oil! It gets used four times per every event.
bobzilla
bobzilla MegaDork
1/2/23 8:12 a.m.
my old hammer store 1.5T aluminum jack only lifts with half a pump now, 9 years into ownership.I should probably clean it up and check the fluid.
WonkoTheSane
WonkoTheSane UltraDork
1/2/23 10:09 a.m.
It may just need bled if you haven't done that recently..
GhiaMonster
GhiaMonster HalfDork
1/2/23 10:13 a.m.
I did one of them in after trying to level a beam at a camp.  The plunger at the base of the handle stopped returning. Disassembly and fixing the rolled seal/ o-ring has it back in action.  This thoroughly reinforced my Jack stand usage.
bobzilla
bobzilla MegaDork
1/2/23 10:26 a.m.
never been done.
slefain
slefain UltimaDork
1/2/23 11:05 a.m.
I was going to throw out my old floor jack until I bled it. Can't believe I didn't know how to do this:
https://knowhow.napaonline.com/floor-jack-wont-lift-heres-a-quick-fix/
WonkoTheSane
1/2/23 1:15 p.m.
Here's a good video I found on filling & bleeding one.  If you search youtube for "bleed harbor freight jack" you'll get a bunch of different hits if your model varies too much from this to make sense of it:
aircooled
aircooled MegaDork
1/2/23 3:36 p.m.
Yeah, I have that exact jack that I have had for 15 years (?).  I did have some pump up issues at one point.  Bleed it, and it was fine.  Probably should check that again at some point.
VlDKsQ3teZPpkAYyn8NAjLOzGfiA1EMGwMN1LMolsQLDgr5BNCBF2WiJuGfZgFNm
