Murphy
Murphy Reader
4/24/19 2:07 p.m.
Having a hard time locating many comparables so figured I’d get some opinions. Looking at a 72 vw bus, no interior , solid body, missing side sliding door. Basically complete restoration from ground up needed, I’m new to the vw bus world.
Any ideas are appreciated thanks
bmw88rider
bmw88rider SuperDork
4/24/19 2:37 p.m.
Is it a camper or just a bus? Camper adds a lot to the value.
Really top notch driver/local show early seventies buses have been hanging out in the high 30s and the campers closer to 50K. I personally think that what you described is not worth more than $1k because it needs so much IMHO. Really, it;s probably be better to use as a shell if you have a bus with bad body work.
Murphy
Murphy Reader
4/24/19 3:32 p.m.
Ya I was thinking I wouldn’t want to spend more than 1k , thanks
ebonyandivory
ebonyandivory PowerDork
4/24/19 3:49 p.m.
In reply to Murphy :
It doesn’t have 23 windows does it?devil
Crackers
Crackers Dork
4/24/19 5:27 p.m.
No interior, no sliding door, no deal. IMO
They have dozens of small panels/crossmembers that all like to rot regardless of region.
californiamilleghia
californiamilleghia HalfDork
4/24/19 7:33 p.m.
Is the motor / trans in it ?
If USA model it would have the Type 4 motor , twin carbs and 1700cc.
Sliding door is not a big deal ,
Rust is just work , repair patch panels are available. Front floors are always rusted.
Probably bucket seats in the front , bench seats were normally on the panel vans ,
If you can drive it around the block it's worth 3k to 5k ,
If you have to rebuild the motor it can be 2-3x as much as a 1600cc bug based motor.
uNrZa2LRyfYIpdl20zJVh4BU1ji0Cr4ZtzfOv87dlYOEaIyXDUymCGuO1FcDhHoZ
