carguy123
carguy123 UltimaDork
9/7/13 9:41 a.m.
Here's an inside look at a V10 F1 head.
Pretty interesting.
CLIFF NOTES - if you're too lazy to read the whole thing, after all it is over a paragraph long, then you don't deserve to learn anything about it.
One thing I thought was real cool was getting to actually see the pneumatic valve actuators both inside & out.
F1 head cutaway
Trans_Maro
Trans_Maro UltraDork
9/7/13 10:11 a.m.
WOW..
Very cool, thanks for sharing.
Lancer007
Lancer007 New Reader
9/7/13 12:07 p.m.
That was an awesome read, thank you for posting!
mazdeuce
mazdeuce SuperDork
9/7/13 1:47 p.m.
That was really cool.
benzbaronDaryn
benzbaronDaryn Dork
9/7/13 2:01 p.m.
Damn that thing is awesome. I'd have read the words but my head would literally explode like and F1 engine at 20000rpm.
oldeskewltoy
oldeskewltoy Dork
9/7/13 4:16 p.m.
WOW.......
9/7/13 8:53 p.m.
Thanks for that.
Kenny_McCormic
Kenny_McCormic SuperDork
9/7/13 10:46 p.m.
Is that, no it can't be, JB WELD?
sobe_death
sobe_death HalfDork
9/8/13 12:05 a.m.
I thought that was a nice addition. In fact, I'm working on my own camshaft squirters using the same idea right now!
carguy123
9/8/13 12:06 a.m.
I noticed that too. i was surprised at how many corners seemed to be cut or make do solutions were used. I think of F1 as cutting edge, but then again they are very low volume engines so I guess stuff like that is the best solution.
daytonaer
daytonaer HalfDork
9/8/13 1:18 a.m.
I wonder if this is the same "Brian G." who made a carbon fiber tea spoon which slowly morphed into casting his own vw cylinder heads and building his own machine shop.
I sure appreciate his detail, and I'm glad some people choose to share their brains on the internet. It is obviously a lot of work to put that post together.
9/8/13 9:25 p.m.
JB Weld is a two-part epoxy, so call it that if you prefer. What kind of cutting edge stuff do you want to see? It's the right solution for something like that.
Kenny_McCormic
9/8/13 9:49 p.m.
IDK, its just kinda scary to think the same thing holding my $400 car's gas tank together is holding bits inside a F1 engine. Something I can buy at walmart.
4cylndrfury
4cylndrfury MegaDork
9/9/13 9:36 a.m.
daytonaer wrote: I wonder if this is the same "Brian G." who made a carbon fiber tea spoon which slowly morphed into casting his own vw cylinder heads and building his own machine shop. I sure appreciate his detail, and I'm glad some people choose to share their brains on the internet. It is obviously a lot of work to put that post together.
It is - Brian Garvey...pretty awesome guy
9/9/13 9:42 a.m.
Kenny_McCormic wrote: IDK, its just kinda scary to think the same thing holding my $400 car's gas tank together is holding bits inside a F1 engine. Something I can buy at walmart.
That means that you're using F1 technology on your $400 car! How cool is that?
I'm sure the stuff in the F1 engine costs far more, though.
93EXCivic
93EXCivic MegaDork
9/9/13 10:56 a.m.
I thought this was going to be about someone cutting into Vettel's head...
Shaun
Shaun HalfDork
9/9/13 12:14 p.m.
Those heads are fantastic pieces of engineering, and the write up was concise and knowledgeable. Great post, thanks for putting that up.
pinchvalve
pinchvalve UltimaDork
9/9/13 12:23 p.m.
So similar to the 4A-GE...
9/9/13 12:23 p.m.
Well, they do have four valves per cylinder and spark plugs. I'm not seeing much else.
Shaun
Shaun HalfDork
9/9/13 1:10 p.m.
think about the splayed valvestems and necessarily complex cam geometry for a sec. hollow cams that spin at 15k and deliver oil at that. really trying to understand what it took to encase the combustion chamber in water and get that out of a single casting made my head hurt. At best one could say they are very very deceptively simple pieces. The duty cycle in insane, the development cycle time constraint unreasonable to the extreme, failure margin vs weight decisions are far from simple as it is a major component part of an assembly that is a stressed member, and on and on and on. Gnarly.
oldeskewltoy
oldeskewltoy Dork
9/9/13 6:22 p.m.
IF you have in-cam oiling.... (Toyota 4AGE) you can drill the lobes to oil each bucket individually... no JB Weld required
the advantage this system has... as rpms increase... more oil is sprayed on the bucket... where as if you depend on oiling through the cam... as rpm increase... so does centripetal force... throwing more of the oil other places..... and NOT on the buckets as much
aUXQIzXveCYOuUEUttHQQEDi9hFPBp3zFoc0BnTeyYvkWBvnP3dimHcmVHvYM2Ul
