I once welded some bottom strut mounts on a set of JIC (? might be wrong on the brand, been a while) struts off a 240SX for a custom install on a Z31 300ZX. The struts weren't rebuildable, so I extended them as far as they would go and did my welds about 1/4" at a time, then sprayed with water and let them cool before going to the next weld. They didn't explode, burn or break so it must have worked.
ncjay
Reader
2/26/11 8:05 p.m.
O.K. I'm going to confess some ignorance here. As I understand it, there are high pressure McPherson struts with rubber o rings, some type of oil, and other assorted sensitive internal parts and you guys are welding on them? Am I missing something?
No, you pull the guts out of the housing, weld your stuff up and then put inserts in. You don't weld on the strut - just the strut housing.
Keith
SuperDork
2/26/11 9:59 p.m.
I've welded on shocks before. Like Curmudgeon said, you just keep the heat under control. Mine were factory Protege5 shocks (Bilstein, I think) that I was installing in a 323 GTX. I had wet rags wrapped around the shocks and a spray bottle of water - they probably get hotter during a fast run down a rough road. Take your time and there's no problem.
Doh. I missed his post when I posted my reply.
That's more excitement than I want for a while. I called Koni last week- I'm using 8610s in the front and they have to ship from Europe. So I won't have them 'till June. After that kind of wait, I'd sure hate to have to weld on them!
Keith
SuperDork
2/26/11 11:45 p.m.
I'd have a different attitude about welding on those versus the set of take-off stock pieces I was messing with!
