frenchyd
frenchyd UltimaDork
3/11/21 6:12 p.m.
They arrived today To keep things simple I plan on using Chevy throttle bodies  but how do I convince my Megasquirt to accept inputs from 2 throttle bodies?
mdshaw
mdshaw Reader
3/11/21 6:26 p.m.
Just use a TPS on 1 & make sure they are setup the same.
Stampie (FS)
Stampie (FS) MegaDork
3/11/21 6:44 p.m.
I'm pretty sure Chevy throttle bodies are way to powerful for a Jag V12.  Might want to look at some Smart car ones.
barefootskater (Shaun)
barefootskater (Shaun) PowerDork
3/11/21 7:01 p.m.
Still waiting on that build thread! Boost that English lump to the moon.
mdshaw
mdshaw Reader
3/11/21 7:04 p.m.
A Jaaaag V12 would be cool. What is it going into? Have been watching all the old Top Gear episodes & lots of Jaaaag V12's on there.
wvumtnbkr
wvumtnbkr PowerDork
3/11/21 7:06 p.m.
Why would you need inputs from 2 throttle bodies?  Are they gonna be independent?
11GTCS
11GTCS HalfDork
3/11/21 7:07 p.m.
In reply to frenchyd :
That right there is a statement sir.   Carry on!
yupididit
yupididit PowerDork
3/11/21 7:12 p.m.
Are they dbw or linkage?
frenchyd
frenchyd UltimaDork
3/11/21 7:40 p.m.
   yes a Jaguar V12 has two. One for the left side and another for the right. Just like Ferrari does and Aston Martin, etc etc
frenchyd
frenchyd UltimaDork
3/11/21 7:41 p.m.
Linkage.
wvumtnbkr
wvumtnbkr PowerDork
3/11/21 7:51 p.m.
I realize they are seperate.  The point is:  are they gonna open the same amount at the same time?  If so, 1 signal will work just fine.
frenchyd
frenchyd UltimaDork
3/11/21 8:06 p.m.
That's a good and valid question.  If I take input from one Side. Does the Megasquirt know it's supposed to feed 12 cylinders? Not just 6?
Mr_Asa
Mr_Asa UltraDork
3/11/21 8:17 p.m.
MS knows whatever you program it to know.
frenchyd
frenchyd UltimaDork
3/11/21 8:32 p.m.
Now that's scary. I'm supposed to write a computer program?   To my knowledge I can't buy one.  Is that something I can have someone do?   If so what is the cost?  Who? What's involved?
EvanB (Forum Supporter)
EvanB (Forum Supporter) MegaDork
3/11/21 9:14 p.m.
http://www.megamanual.com/MSFAQ.htm
Time to start reading.
mdshaw
mdshaw Reader
3/11/21 9:30 p.m.
MS is very simple really. The "programming" is done, so it knows you want to squirt & fire,  but you do the tuning to tell it when & how much to squirt & when to fire.
 I built one years ago for a Honda that I converted from carb to mpfi. I could never get the ignition to work correctly so I just used the vacuum advance but the tuning was fun. Cops I think would have been easier than trying to deal with that old distributor.
I bought the added app from a guy that auto learned but still had to do a lot of tuning.  It ran really well eventually.  I learned just how hard it is to start a cold motor with fi.
Hopefully you don't have variable valve timing or lift. With turbos you'll have another dimension also.
With the little D15B2 in the CRX when tuning full throttle & data logging on an empty road,  speeds could still get up there.  A twin turbo V12 at full throttle will probably require a lot of empty road or optimally a dyno. A good experienced MS tuner could have it tuned in a few hours on a dyno.
I still have the simulator you could borrow to test all the sensor inputs/outputs to your MS ecu. It beats troubleshooting a mis-wired or bad sensor.
81cpcamaro
81cpcamaro Dork
3/11/21 9:37 p.m.
The Megamanual is old, I would use the Msextra manuals: https://www.msextra.com/manuals/
yupididit
yupididit PowerDork
3/11/21 9:52 p.m.
frenchyd said:
Linkage.
Use one TPS. Make sure both throttle bodies open the same amount at given throttle.
Which MS are you using?
Stefan (Forum Supporter)
Stefan (Forum Supporter) MegaDork
3/11/21 10:15 p.m.
It doesn't care.  It takes the inputs and applies those to the tables that you setup and outputs the proper injector open time, etc.
When you set it up, you put in the basic parameters of the engine size, number of cylinders, injectors, etc and it outputs the base fuel settings that all of the fuel tables are calculated off of.
it doesn't care if you have a million cylinders or two, it just needs to know how long to open the injectors and when.
There are physical limitations to what it can control, but the software itself doesn't really care.
So set it up to read the TPS from one throttle body and make sure they are both connected and open the same amount at the same time and you'll be fine.
frenchyd
frenchyd UltimaDork
3/12/21 6:26 a.m.
Next issue. The original Lucas ECM is in the trunk. Is there any reason for me to keep the Megasquirt there?  I was thinking of putting it  where the glove box would be in a street car. ( for ease at pugging in my lap top and making changes on track).
frenchyd
frenchyd UltimaDork
3/12/21 6:27 a.m.
yupididit said:
frenchyd said:
Linkage.
MS1.
frenchyd
frenchyd UltimaDork
3/12/21 6:37 a.m.
I did last night. And in about 15 or 20 Re readings I'll understand.  Some of the trouble is translation. Tech guys love jargon and abbreviations. It's just their  nature.
    My "advantage" is when I was a young teenager  the corner gas station bought a wall of tuning equipment and I quickly learned how to use it.  The giant O scope would show all the cylinders firing and reading from them you could see ignition issues, timing, fuel issues etc of each cylinder.  You quickly could see, " oh the left bank of the carburetor is plugged or the accelerator  pump  isn't working etc".
So I know how to tune.  Learning  how to do that with a keyboard will be new for me.  What I really need is a grizzly old guy to smack the back of my head when I start to enter the wrong thing.
       No Stampie. You can't have the job!
frenchyd
frenchyd UltimaDork
3/12/21 6:46 a.m.
That's extremely generous of you.  I will take you up on your offer.
    Yeh,  dyno time makes a lot of sense.
     The ignition system on a Jaguar is independent of the fuel system. I wonder if initially for simplicity sake I can just use that and get the Megasquirt understanding the fueling requirements?
Paul_VR6 (Forum Supporter)
3/12/21 7:06 a.m.
I have six throttle bodies and one TPS, it's really a non issue. You are only using the TPS for accel enrichment (based on rate of change) and decel fuel cut if enabled.
Your lack of understanding is making this sound WAY more complicated than it actually is. Engines are engines and there's nothing super special about the Jaaag other than having a few more cylinders you need to be mindful of.
I wouldn't use the stock ignition control, it would need some serious bandaids to work on a boosted setup.
Also, the megamanual is good for basics, but most are running newer firmware and msextra.com has the current details on what is/isn't possible on the different versions.
The ecu can be mounted anywhere the wires can reach.
I am willing to help but 400 different threads on GRM are hard to keep track of! laugh
dean1484
dean1484 MegaDork
3/12/21 7:13 a.m.
How are you handling ignition?  I think you should forgo TPS and use a MAP sensor versus RPM to tune it. You are going to need to know the MAP anyway to tune with boost. I would put a separate MAP on each Mansfold to see what both sides of the motor are doing. I would have to think about if I would average the two for the MS and Wright somthing that then monitored the two for variance so in case you had a problem with one side and the MS was reading low boost on half the motor when there was full boost on the other half but was not getting enough fuel or not enough timing pulled causing bad things to happen. You could just take vac/boost from both sides to a T connection to the MAP. Put a big enough crossover and you then don't have to worry about this. Thinking more about this I would definitely do this. It would make tuning much easier.
oaTK7dn3APexKeq3gIcjzdui53TVHg1QsrWb1Hz2ffmnL93zDnwqT7jXPePIyieh
