http://www.wallaceracing.com/calc-cfm-head.php
Not perfect but it will show you the effects, if you search a little bit you can find all the underlying math.
Paul_VR6 (Forum Supporter) said:http://www.wallaceracing.com/calc-cfm-head.php
Thank you that is exactly what I was searching for.
In reply to Slippery :
In simple terms If I can achieve that sort of flow. Plus survive at that sort of RPM. I believe I can successfully compete in SVRA's Group 6
I'm going off 30 years memories but I believe the Flathead (1971-1980) stock flowed about 220 CFM and I believe it opened up to over 300 CFM. @.500 lift.
There recently was a great deal of write up about the flow achieved on the Jaguar forum. I'm going to spend some time looking for those numbers for confirmation.
ps, looked at the bore and stroke of the S2000 and compared it to the bore and stroke of the Jaguar.
Honda Jaguar
stroke 84 mm 70 mm
bore 87 mm. 90 mm
So obviously Honda's piston speed would be much high than Jaguars.
While the Jaguar's piston size would make it heavier than Honda.
Am I correct in assuming the S2000 has a cast piston? ( I can't imagine new Honda owners putting up with the piston slap of a forging).
frenchyd said:In reply to Slippery :
Rods/Pistons/Crank are all forged on S2000s. The block has FRM walls.
As is Jaguar They are forged of the same metal used in Cosworth Formula 1 engines. Except pistons. Which are cast. ( and seriously lighter than forgings)
Are you absolutely sure the pistons are forgings. Because of the greater expansion rates of forging over castings. There will be a noticeable piston slap on a Forging that isn't there on a casting.
Some of the modern casting process allow remarkable strength , approaching forgings.
Slippery said:frenchyd said:In reply to Slippery :
Am I correct in assuming the S2000 has a cast piston? ( I can't imagine new Honda owners putting up with the piston slap of a forging).Rods/Pistons/Crank are all forged on S2000s. The block has FRM walls.
What are FRM walls?
frenchyd said:Slippery said:frenchyd said:In reply to Slippery :
What are FRM walls?
Fiber Reinforced Metal
Yes you are right they are forgings!! I wonder what they weigh?
F20 = 350 grams
F22 = 330 grams
Thank you .
The Jaguar liners are some sort of high wear resistant steel I've seen engine with very high miles and almost no measurable wear. I don't know if that's because of the 70 mm stroke or some voodoo steel. I do know you can't break them with a 20 pound sledge hammer.
F20 = 350 grams
F22 = 330 grams
That's light!!!! My forged Jaguar piston Is 480 grams. But Cosworth has forgings 100 grams lighter with a better combustion chamber. ( there is no combustion chamber in the head, it's in the piston)
frenchyd said:In simple terms If I can achieve that sort of flow...
With two valves they are going to need to be big and the ports to match. The FXX heads are some of the best OEM heads ever cast.
What is your max valve size? Can you get close to the same area?
In reply to Paul_VR6 (Forum Supporter) :
I am quite confused by this engine Frenchy keeps talking about. What engine is it? I thought it had 4 valves/cylinder.
