Knurled.
Knurled. MegaDork
7/4/19 5:41 p.m.
Half shafts should have CVs  Wheel bearings GENERALLY don't make clunking noises, but rather whirring or rumbling noises.
Without hearing it for myself, I'd wonder if the diff bushings are weak and the nose is dropping under decel, causing the guibo to bind.   Or it could be something else entirely.
Streetwiseguy
Streetwiseguy MegaDork
7/4/19 6:13 p.m.
Side gears/spider gears loose in the case, like worn out from the one wheel peel is possible.  If limited slip, is one tire smaller than the other, causing the clutches to ratchet when unloaded?
Bob_S
Bob_S New Reader
7/4/19 6:50 p.m.
Could be a driveshaft U-joint
manladypig
manladypig New Reader
7/4/19 7:05 p.m.
Got anything in the trunk? hehe
52DaT8TigwFaf0bmpELO3GZdVGU7nivQlQumBmxXPoodSEJuaYijcD1MBwRqPcYS
