RealMiniNoMore
RealMiniNoMore PowerDork
4/25/19 8:09 a.m.
Daughter's 2011 Subaru Legacy keeps puking rear calipers. They seize up. I've liberally greased the sliders, but it seems like the pistons also seize in the bores. It's happened a few times. I'm tired of changing chewed up rotors.
02Pilot
02Pilot SuperDork
4/25/19 8:12 a.m.
Have you confirmed the pistons are actually stuck? Could it be fluid pressure from the ABS pump or an internally swollen soft line?
Daeldalus
Daeldalus Reader
4/25/19 8:16 a.m.
Any time a caliper locks up like that the first place to look is the rubber hose. I would replace both rear before anything else.
RealMiniNoMore
4/25/19 9:29 a.m.
Ah, never thought about the line! I'll check that out.
The last time it chewed up a rotor, I just replaced the caliper without checking it over. It definitely took considerable force to get the pads open, to remove the caliper, which points to restricted flow...
This time, I'm going on the basis of report from 715 point checklist while getting an oil change. Daughter did say her brakes were making noise... again...
RealMiniNoMore
4/25/19 9:31 a.m.
Should I go with braided stainless lines, or just regular rubber?
NickD PowerDork
4/25/19 9:35 a.m.
It also just seems to be a thing with Subarus where they chew through brake parts. My Baja needed all 4 calipers when I bought it. Within 5000 miles one of them was dragging again, and it was the caliper, not the hose. A friend of mine's '17 Outback has had all the calipers replaced already. My sister's Forester and mother's Outback have also all have them replaced multiple times.
4/25/19 10:05 a.m.
Regular rubber. Braided stainless has to be longer to allow for less flexible lines and thus becomes a packaging PITA. It also tends to fail without visible or pedal-feelable warning, unlike rubber.
RealMiniNoMore
4/25/19 10:07 a.m.
In reply to GameboyRMH :
Thanks for the advice !
Stefan
Stefan MegaDork
4/25/19 11:03 a.m.
Worth looking at the hard lines too, there may be a kink or a dent along the way that could be causing constriction, etc.
Brett_Murphy
Brett_Murphy UltimaDork
4/25/19 11:22 a.m.
Is it a manual? My Subaru's hill holder feature decided to get wonky and keep pressure applied to the passenger side rear caliper. I just disconnected it.
RealMiniNoMore
4/25/19 11:39 a.m.
In reply to Brett_Murphy :
Shift-O-Matic, but I think I might have seen a switch on the dash for something about the brakes?
5qeQCuJwwVW5Kyn5pBBBDVi4S267FbOrIuSzqpaTlnRULVisWJkGwrx44mvAcxFB
