TurboFocus
TurboFocus HalfDork
1/13/20 9:37 p.m.
Car is not mobile, I don't have any particular attachment to the wheel so an angle grinder, hammer and chisel might be the right answer for me... I might try to take the whole spindle off and remove it from the back first. worst case scenario, I have a neighbor who enjoys black smithing
Curtis73
Curtis73 UltimaDork
1/13/20 9:49 p.m.
I've used a chisel bit in my air hammer before.  Worked well.
DuctTape&Bondo
DuctTape&Bondo Dork
1/13/20 10:38 p.m.
I have this and used it successfully on every lock I've tried it on so far; Twist socket Amazon
Includes numerous junkyard wheel locks and three off my LS430 because I broke the key using an impact wrench (doh!)
No hammering usually just shove it on with my Ryobi 18v cordless impact and it does all the work.
Woody
Woody MegaDork
1/14/20 7:06 a.m.
Just ordered that kit. Thanks for linking the link.
I don't currently have this problem, but I suspect that I will someday, and I will be thankful to have a solution on hand.
Toyman01
Toyman01 MegaDork
1/14/20 7:37 a.m.
In reply to DuctTape&Bondo :
Shanky Auto Tools. What a great name. I might buy a set just for that.
TurboFocus
TurboFocus HalfDork
1/14/20 8:34 a.m.
Now this is interesting, only the 22mm looks like it would work
The0retical
The0retical UberDork
1/14/20 8:53 a.m.
Took a bit to find this, but I knew I made a comment on Reddit when someone found lug nut sheared off at the base.
You don't have much clearance, so a ripper might not work. You can use an annular cutter, and a boat load of lube, if you can't get access to drill out the stud or get a key. I'm pretty sure there's a special one for lug nut applications but I can't find it.
Gearheadotaku
Gearheadotaku UltimaDork
1/14/20 11:03 a.m.
For the rear you could slide the axle shaft out and get to the back of the stud. Pull the c clip and the whole wheel and drum assembly should come off right?
Knurled.
Knurled. MegaDork
1/14/20 1:15 p.m.
In reply to Gearheadotaku :
Depends, usually the drum sits so close to the backing plate that you won't be able to push the axle in enough to remove the clip.
It's worth a messy try, anyway.
wheelsmithy
wheelsmithy UltraDork
1/14/20 1:28 p.m.
nimblemotorsports
nimblemotorsports Reader
1/14/20 1:41 p.m.
if you don't care about the wheel, use a angle grinder with aluminum cutoff and cut off the wheel around it so you can spin the aluminum to unscrew it.
Had same problem on my GT6, but I saved my wheels with just minor damage using cut off wheel on the nut itself.
Vigo MegaDork
1/14/20 9:57 p.m.
TurboFocus
TurboFocus HalfDork
1/18/20 10:47 p.m.
Ended up sacrificing the center caps, used an angle grinder to shave off some of the material for a smaller diameter and hammered a socket on.
Struggled a bit, but it worked without damaging the wheel a whole lot
YFs1NiNd0owjkOSLHIqIa6o03cpMgmRI1bJZnxcxnxBe2KIzSdoMvZrVWcYvsFFI
