fastbmw
fastbmw New Reader
2/23/11 5:57 p.m.
My brother's e30 touring has an annoying steering wheel vibration, it's nothing major just a tiny side to side wobble that he wants to get rid of. (wobble is felt at speeds over 60kph, most noticeable at 110kph)
Here are the details
  • Brand new front suspension (Bilsten shocks, shock mount, control arms, tie-rods)
  • Brand new ASA AR1 wheels w/+10mm spacers supplied by Tire Rack -3 year old Kumho SPT with about 90% tread (the tires sat for 2 years but the tire shop said they were balanced on the ASA wheels).
  • 2 year old front wheel bearings
  • 2 year old steering rack
With the brand new front suspension, the only cause of the vibration that I can think of would be the spacers. Is there anything else I am forgetting? Is there a fix to make the spacers vibration free?
Tom Suddard
Tom Suddard SonDork
2/23/11 7:04 p.m.
What kind of spacers are they? Are they the kind that are fit to center themselves on the hub?
porksboy
porksboy SuperDork
2/23/11 7:44 p.m.
Did the tires sit on wheels on a car? If so maybe they are flat spotted.
Can you run the wheel/ tire combo be run with out the spacers? Maybe by not turning the wheel lock to lock.
Streetwiseguy
Streetwiseguy Dork
2/23/11 8:08 p.m.
I presume, being German, the wheels are held with bolts, not studs and nuts. If the wheel spacers are too thick to allow the wheel to center on the hub, or if the hole in the wheels is too large to center, it will always shake.
My experience has been that you can get away with non hubcentric wheels on studs, but not with bolts.
rodrammage
rodrammage New Reader
2/23/11 9:24 p.m.
Those BMWs use hubcentric means to mount the wheels. Your spacers must be of the hubcentric variety as well.
iceracer
iceracer Dork
2/24/11 9:33 a.m.
If the spacers move the wheels out enough it could cause a problem like that. Also, check for wheel/tire run out, radial and lateral.
SupraWes
SupraWes Dork
2/24/11 4:02 p.m.
Were the lolipop lower control arm bushings replaced also? Jack it up and start grabbing wheels, shouldnt be too hard to find.
7pAVLB0OYud5vcufsChutY2T7IQ4667HeeM3JKasBjfNuIwMYNdl6bJdZsaRnEzz
