Donebrokeit
Donebrokeit SuperDork
11/6/19 10:30 p.m.
Next season I am planning to run Hoosier  245/40/15 A7 tires on an NA Miata, not worried about fenders.  Would a 9-inch wide wheel (Advanti Storm) be wide enough or should I just pony up and get the 10-inch wide wheels?
Paul
manladypig
manladypig New Reader
11/7/19 12:15 a.m.
9 inch will be plenty I'm pretty sure, I have 225's on 8 inch wheels and they fit perfect; no bulge, no stretch. Considering 225mm is 8.8 inches and 245 is 9.6 I think It should fit nicely. It will definitely fit though, There is a another miata on the forum I saw running 225's on 6.5 inch wheels!
Rodan
Rodan Dork
11/7/19 7:18 a.m.
If your goal is max performance get the 10s.  How wide a wheel should I get?
General rule for Miatas:
205 on 8s
225 on 9s
245 on 10s
I think the Konig Dekagrams are the only 15x10 in stock anywhere right now.
z31maniac
z31maniac MegaDork
11/7/19 7:25 a.m.
The fast Miata guys run a 205 Hoosier on 9" wheels, for example.
10" would be the minimum, I think some guys are even running the 245s on 11" wheels.
maschinenbau
maschinenbau SuperDork
11/7/19 8:13 a.m.
I ran 245/40R15 A7's on 15x8's at the Challenge. They were awesome.
Rodan
Rodan Dork
11/7/19 8:27 a.m.
Konig also makes the Freeform in 15x9.5 in a Miata fitment.
codrus
codrus UberDork
11/7/19 9:18 a.m.
A 205 on 9 will be slower than a 245 on a 9.
People used to run 275 Hoosiers on 15x6 wheels when Stock allowed any DOT tire.  Yes, it was pinched, and yes, it was not using the full potential of those tires due to the narrow wheel, but given the class rules that required stock wheel size it was still the fastest option for autox.
dps214
dps214 Reader
11/7/19 9:41 a.m.
Came here to post this. I'd honestly be surprised if anyone has ever put a 205 width hoosier on a 9" wide wheel on purpose. As long as you can physically mount them you can put the tire on just about as narrow a wheel as you want and it'll still work decently, just feel like absolute garbage. But to answer the OP's question , i'd put those tires on a 9" wheel all day long, even an 8 if I had to. Any narrower on the wheel than that and I'd want a narrower tire unless I was only looking for outright speed and not driving enjoyment.
Patrick
Patrick MegaDork
11/7/19 9:44 a.m.
I mounted 245 a7's on 8.5 wheels for the challenge and it was a pain in the junk, a 9.5-10" wheel would have been preferable.
z31maniac
z31maniac MegaDork
11/7/19 11:36 a.m.
Yes, they have. Many, many times. Check the Race Prep section and build sections on MiataTurbo.
Rodan
Rodan Dork
11/7/19 12:07 p.m.
The 205 Hoosier runs wider than most 205s, so it's an outlier.  Lots of folks run them on skinny wheels because that's what they have, or what their class rules allow.  It doesn't mean it won't be faster on a wider wheel.
L5wolvesf
L5wolvesf New Reader
11/7/19 6:00 p.m.
Per Hoosier: Recommended wheel width for that tire is 8.0 - 9.5
https://www.hoosiertire.com/assets/Circuit%20Racing5.pdf
JbJBCUptE6gSeJIEhpb6qj3wmXq2l7qyzb21jOzOr2RrShUU9SWD9RJFEWxoKMGh
