captainzib
captainzib HalfDork
6/7/10 3:43 p.m.
Can they still be taken to a shop that'll turn em and then reused?
I feel like this is a noob question, but I've never had rotors turned, and I don't think these have any grooves, just rust.
16vCorey
16vCorey SuperDork
6/7/10 3:46 p.m.
As long as they mic out and have enough meat to turn, then absolutely. Actually, if they're not grooved or warped, and within spec, just hit them with a sander and knock the rust off. The second one down looks pretty thin on the back side. I think I'd pitch that one.
DeadSkunk
DeadSkunk Reader
6/7/10 4:02 p.m.
Soak them in a tub of vinegar for a couple of days. The rust will just hose off and you'll be able to measure their thickness very easily.
captainzib
captainzib HalfDork
6/7/10 4:14 p.m.
16vCorey wrote: The second one down looks pretty thin on the back side. I think I'd pitch that one.
I noticed that too.
I've always been told that when doing a brake job, to always have the rotors turned, or to replace em, and I've always been too lazy to reuse the old rotors.
In my younger, more oblivious days, I used to just change pads and ignore rotors since the pad wear was obvious and the rotor wear wasn't, I just assumed that rotor wear was negligible.
A buddy recently got me a 50% discount on ATE pads and rotors, so I was all ready to throw away these old ones, but then I thought if they were still usable it'd be a complete waste.
skruffy
skruffy SuperDork
6/7/10 4:18 p.m.
You only need to replace rotors if they're worn. There's nothing wrong with throwing a new set of pads on without doing anything else.
captainzib
captainzib HalfDork
6/7/10 4:24 p.m.
That's what I always thought skruffy, but I was told that I've been half-assing it by a friend, and I didn't want to neglect the other half.
grimmelshanks
grimmelshanks Reader
6/7/10 4:25 p.m.
^NOT CORRECT!!! pads rubbing against rotors create what is called a wear pattern. if you just slap in new pads the contact patch of pads against rotors will be smaller because if inperfections in the rotor, causing you to not stop as well. it takes like 15 minutes, have the rotors cut.
Marty!
Marty! Dork
6/7/10 4:57 p.m.
Getting a clean machined surface is critical to getting new pads to bed in correctly. If you're on a budget at least scuff the rotor surface real good, but for the $9 it costs to have them turned I see no reason to skip this step.
porksboy
porksboy Dork
6/7/10 5:02 p.m.
Thats part of what you do when you bed the pads. Not only is the friction material "curing" and transfering itself somewhat to the rotor you are also contouring the pad to the rotor.
I never replace a rotor unless below specs or cant be turned out. I also never turn a rotor unless I am trying to eliminate a vibration or cure a pulse or the rotor is deeply grooved.
When I worked for Mercedes we only replaced rotors when worn out and NEVER turned any. This was by recomendation from Mercedes in Germany.
John Brown
John Brown SuperDork
6/7/10 5:04 p.m.
New rotors are always cheaper than a new spleen.
porksboy
porksboy Dork
6/7/10 5:07 p.m.
John Brown wrote: New rotors are always cheaper than a new spleen.
Yes, but do you replace the engine when you change the oil?
How about the master cylinder and calipers when you flush the brake fluid?
Johnboyjjb
Johnboyjjb New Reader
6/7/10 5:42 p.m.
I've been informed by a few different brake manufacturers, mainly Centric and ATE, that rotors that are grooved, pitted, or rusty should be turned. A groove being 1/16 of an inch deep. Thickness variation is something else to look for. And if you don't have a lathe or can't do it yourself I would rather reuse the rotor than pay someone to machine it. I've seen a lot of rotors ruined by bad machine jobs.
iceracer
iceracer Dork
6/7/10 5:53 p.m.
Don't forget, machining the rotor reduces the heat sink capabilities of the rotor.
Unless the rotor has build up (warped) or grooved, there is no need to turn them When I replaced pads, I clean the rotor with brake clean and a light sanding. Takes a couple miles for the new pads to bed in.
Ian_F
Ian_F Reader
6/7/10 6:01 p.m.
I had some rotors that looked similar - no grooves, just surface rust from being stored in too much humidity. I soaked them in Evapo-rust ($20/gal from H-F) over night. All rust gone, they looked like new and pads bedded in fine.
John Brown
6/7/10 6:40 p.m.
Yes, but do you replace the engine when you change the oil? How about the master cylinder and calipers when you flush the brake fluid?
Replace the driver when you open the door? Replace the tank when you refill it? I can do it too!
New rotors will always offer a better surface than machined or used units and as long as they meet the OE spec (some may not) they will always last longer than machined or used. In a performance setting using new rotor blanks will help you to stay out of trouble. New rotors are indeed cheaper than a new spleen.
artyboy619
artyboy619 New Reader
6/7/10 8:29 p.m.
The two rotors in the middle(the solid discs with the deep hat) arent really machinable. The center depth is near impossible to mount in the brake lathe and flexes when the cutting. essentually warping the rotors while resurfacing.
theres my two cents.
Rusnak_322
Rusnak_322 Reader
6/7/10 8:33 p.m.
"New rotors will always offer a better surface than machined or used units"
what is the new rotor surface finish if it is not machined?
splitime
splitime Reader
6/7/10 8:41 p.m.
For what they seem to charge for brake resurfacing anymore... its almost the same price to get new rotors. At least in my applications.
neon4891
neon4891 SuperDork
6/7/10 9:32 p.m.
If I had a lathe, I would turn my own rotors. I loved doing it. But I'm not sure of any local shops that still do that. And I dont feel like leaving my car up on stands long enough to have someone else do it.
But a brake lathe is my #1 item on a garge tool list...
shadetree30
shadetree30 Reader
6/7/10 9:40 p.m.
captainzib wrote:
How the hell did you get into my basement?
grimmelshanks
6/7/10 10:40 p.m.
dude, totally not the same thing
John Brown
6/7/10 11:00 p.m.
Rusnak_322 wrote: "New rotors will always offer a better surface than machined or used units" what is the new rotor surface finish if it is not machined?
Born from jets?
thecounterman
thecounterman None
6/8/10 1:50 a.m.
iceracer wrote: Don't forget, machining the rotor reduces the heat sink capabilities of the rotor. .
Exactly, and then you run into warping issues.
zomby woof
zomby woof HalfDork
6/8/10 7:25 a.m.
Did I stumble on to a Honda forum by accident?
Twin_Cam
Twin_Cam Dork
6/8/10 7:30 a.m.
I buy the $18 apiece rotors so I don't have to have this argument with myself. It's cheaper than getting them turned.
SVbie7nGFL2sWMRoac5ugqqCYz2LL5y49VgPAGgwwiJDi6jiRlFdH6KpSyub7oVY
