DrBoost
DrBoost UltimaDork
11/4/14 7:09 p.m.
I need to make some motor-mount bushings, and I'm thinking poly would be the way to go. Where can I gets me some poly stock so I can chuck it on a lathe and make a mess?
Dr. Hess
Dr. Hess MegaDork
11/4/14 7:45 p.m.
McMaster-Carr.
DrBoost
DrBoost UltimaDork
11/4/14 7:48 p.m.
I forgot to ask. I know next to nothing about poly bushings. Is there a particular flavor material I should be looking for?
grafmiata
grafmiata SuperDork
11/4/14 8:04 p.m.
DrBoost wrote: I forgot to ask. I know next to nothing about poly bushings. Is there a particular flavor material I should be looking for?
Can't go wrong with butterscotch.
Dr. Hess
Dr. Hess MegaDork
11/4/14 8:16 p.m.
Delrin.
MrJoshua
MrJoshua PowerDork
11/4/14 8:20 p.m.
Bathroom stall walls
moparman76_69
moparman76_69 SuperDork
11/4/14 8:35 p.m.
hockey pucks.
ebonyandivory
ebonyandivory SuperDork
11/4/14 8:45 p.m.
The garage that helped build my buddy's Jeep had several feet of body mount stock. Maybe the same durometer rating as what you need?
Derick Freese
Derick Freese UltraDork
11/4/14 10:01 p.m.
Ever since MrJoshua showed me the pleasure of cutting round holes out of bathroom walls, nothing else seems to fill my needs for as little initial outlay.
SVreX
SVreX MegaDork
11/4/14 10:34 p.m.
BTW, we checked for play and wear...
...those bathroom stall partition bushings are still good 6 years later.
Fueled by Caffeine
Fueled by Caffeine MegaDork
11/4/14 10:44 p.m.
Derick Freese wrote: Ever since MrJoshua showed me the pleasure of cutting round holes out of bathroom walls, nothing else seems to fill my needs for as little initial outlay.
Those holes, so glorious
Nick_Comstock
Nick_Comstock PowerDork
11/4/14 10:53 p.m.
I came for the knowledge of bushings. I stayed for the glory holes.
itsarebuild
itsarebuild HalfDork
11/5/14 7:58 a.m.
Are you using the solid phenolic bathroom stall material? That is an awesome idea!
jimbbski
jimbbski HalfDork
11/5/14 8:31 a.m.
For motor mounts, at least for FWD applications I would buy two-part liquid urethane and just mix and pour it into a mold. You can get various levels of hardness/stiffness. Even Energy Suspension now sells liquid urethane for those who want to make their own. I buy mine from "Eager Plastics" in Chicago since it's local. http://www.eagerplastics.com/
If for a suspension bushing that rotates, then I would buy a round bar and machine it.
SVreX
SVreX MegaDork
11/5/14 9:57 a.m.
itsarebuild wrote: Are you using the solid phenolic bathroom stall material? That is an awesome idea!
Yes.
itsarebuild
11/5/14 10:04 a.m.
Sweet! I just got 10 coaster size color samples for a school job I'm working on. I may need to try this!
Leafy
Leafy Reader
11/5/14 12:01 p.m.
If you have a weird shaped mount buy 2 part urethane an cast them. If you have something you can make in a lathe just buy the damn bushing already made based on sizing.
SVreX
SVreX MegaDork
11/5/14 12:47 p.m.
Leafy wrote: If you have a weird shaped mount buy 2 part urethane an cast them. If you have something you can make in a lathe just buy the damn bushing already made based on sizing.
I take it you've never been to the $20XX Challenge.
Leafy
Leafy Reader
11/5/14 1:00 p.m.
No, but when your piece of stock costs $10 after shipping and the bushings you need to purchase only cost $6.xx and dont require you to spend any time its a pretty easy decision.
SVreX
SVreX MegaDork
11/5/14 1:03 p.m.
In reply to Leafy:
Challenge math. Does not compute.
Swank Force One
Swank Force One MegaDork
11/5/14 1:08 p.m.
If your $10 stock piece can make 10 bushings, it's only a $1 budget hit. Way better than $6.xx.
Leafy
Leafy Reader
11/5/14 1:19 p.m.
I thought lemons math was bad.
Swank Force One
11/5/14 1:26 p.m.
Leafy wrote: I thought lemons math was bad.
I don't see how this is bad. You claim on budget what's on the car. You didn't use the whole $10 stick of poly, you used a portion of it. That portion goes in budget.
Pretty simple.
Leafy
Leafy Reader
11/5/14 1:29 p.m.
I don't see how this is bad. You claim on budget what's on the car. You didn't use the whole $10 stick of poly, you used a portion of it. That portion goes in budget. Pretty simple.
But you had to buy the whole stick, it still cost me $10 to make it. Do you get to claim that your turbo you added only cost $150 because you bought 10 containers full of them from china but only used one of them?
Swank Force One
11/5/14 1:34 p.m.
You'd count tools on the budget too, then?
jGk0EPWDQi3D2a4Jbmv1yaZ3po8Q6oS8vPY4ZUwknvkkANiaFUrezVWyxmn9F0zW
