Spearfishin
Spearfishin HalfDork
12/21/24 8:16 a.m.
Looking for a K.I.S.S. mounting solution that'll let me simply move a single winch across a couple of trailers and also mount on my shop floor to get things yanked into the side bay. I was envisioning some sort of flat plate that stays with the winch with a pair of keyholes for some largish bolts that I'd have permanently on each trailer/shop floor.
Anyone think of a more elegant solution?
RevRico
RevRico MegaDork
12/21/24 8:19 a.m.
Hitch receivers are popular. Mount the winch on the male part, and put females where needed. Front bumper, trailer, work bench.
I've seen it a lot in the off-road world so I *assume* it would be fine for vehicles not stuck in deep mud as well.
cyow5
cyow5 HalfDork
12/21/24 8:21 a.m.
cyow5
cyow5 HalfDork
12/21/24 8:22 a.m.
Rev beat me to it
Spearfishin
12/21/24 8:24 a.m.
I thought about that. The only negative I could come up with is that in my enclosed trailer the receiver would be a little in the way "the rest of the time". Figure if I had nuts welded on the backside for my "bolt/keyhole" solution, I could just snug the bolts all the way down when I didn't have the winch in the enclosed trailer, or remove them (and promptly lose them).
TJL (Forum Supporter)
TJL (Forum Supporter) SuperDork
12/21/24 8:24 a.m.
I did the hitch mount receiver with nice electrical connectors on my golf cart. Move it front or back depending on how I needed to pull myself out.  It could easily be adapted to fit a trailer too.
californiamilleghia
californiamilleghia UberDork
12/21/24 11:37 a.m.
Take the flat plate and drill a hole to fit a 2 inch ball ,  also some holes with slots to hook a chain into ,
I have used this  plate to wrap a chain around a tree , hook in  and pull a dead car around the yard..
Same plate can be used on a trailer , either bolted on or chained around the tongue ,
jgrewe
jgrewe Dork
12/21/24 12:10 p.m.
If you aren't trying to drag something without wheels, E track would probably be strong enough. Maybe two strips of it if you are worried about the load.
I use a 4500lb ATV winch in my trailer and it never struggles with a rolling car or truck.
L5wolvesf
L5wolvesf Dork
12/21/24 12:31 p.m.
Similar to this . . . On my trailer the receiver is mounted vertically and even with the deck. It is never in the way of anything. I just drop the winch into the receiver.
SV reX
SV reX MegaDork
12/21/24 1:02 p.m.
I embedded a piece of 2" square tubing in the concrete floor of a shop- the male receiver hitch would slip right in.
2nd idea... My trailer has a winch permanently mounted on it with a long cable.  My current shop has a hook in the front wall. I mount a cable snatch block to it and can pull cars into my shop with the trailer parked outside without de mounting the winch.
codrus (Forum Supporter)
codrus (Forum Supporter) UltimaDork
12/21/24 6:15 p.m.
So as a random thought -- I've been told that Harbor Freight's winches are actually pretty decent these days, and they have a 2000 lb "trailer/utility" winch for $50.  So maybe it's easier just to buy a couple of those?
pkingham (Forum Supporter)
pkingham (Forum Supporter) Reader
12/21/24 7:47 p.m.
I have a small winch mounted to a plate, and I added a strap with a hook.  In the shop I have  D-ring bolted to the floor which isn't particularly in the way.  That could be replicated in a trailer or just use existing mounting points.
ShinnyGroove (Forum Supporter)
ShinnyGroove (Forum Supporter) Dork
12/22/24 10:09 a.m.
Absolutely. I have one of those in my race trailer and I've been using it to load/unload for 5 years without issue.  I hook it up to a $50 LiPo motorcycle battery I got off of Amazon.  I just bolted it to the floor with fender washers. For $50 each, just buy a couple winches and don't worry about moving them. The mounting hardware to move it around will end up costing more than another winch.
Spearfishin
12/22/24 12:58 p.m.
But I already sent the wife the for the 5k lb model! Haha
38bAwiyfjt9D6zB10vN03Wwdt0Id5hoc2p0iwuaHfZ18ykMDkC8O4tWYzkprWhCk
