patgizz
patgizz PowerDork
8/13/14 9:53 p.m.
simple question.
i've always dealt with huge american cars that require 15+ feet of battery cable to trunk mount.
the new car is imported, therefore small compared to my large american penis, i mean car. approximately 9 feet of cable is required to go from kill switch to starter.
what gauge to run without going too big(weight) versus able to carry the current? i've always used 2 gauge, but this was for runs 6 feet longer than i need this time.
grafmiata
grafmiata SuperDork
8/13/14 10:08 p.m.
No idea. But if you decide to stick with 2-guage, I have a couple 25-foot rolls that I'd let you cut a chunk off of.
Swank Force One
Swank Force One MegaDork
8/13/14 11:12 p.m.
Depending on what you're running, 4awg is fine.
Woody
Woody MegaDork
8/14/14 6:13 a.m.
Approximately this gauge:
http://jalopnik.com/5107178/junked-bmw-e30s-provide-cheap-easy-way-to-trunk-mount-your-battery
DeadSkunk
DeadSkunk SuperDork
8/14/14 7:05 a.m.
Whatever the welder cable size is at the local Tractor Supply store.
ross2004
ross2004 New Reader
8/14/14 9:40 a.m.
http://www.gtsparkplugs.com/WireSizeCalc.html
A junkyard E30 makes for an excellent donor.
bmwbav
bmwbav Reader
8/14/14 10:11 a.m.
2 gauge is perfect. The E30 is indeed a good source, I have an E36 cable in my car.
Even better is a brand new kit that doesn't require you to go to a junkyard and includes a bunch of stuff you might want anyways.
http://www.amazon.com/NOCO-BTMK1-Black-Group-Battery/dp/B004QCBLEM/ref=sr_1_1?ie=UTF8&qid=1408028921&sr=8-1&keywords=battery+trunk+mount
patgizz
patgizz PowerDork
8/14/14 8:18 p.m.
that kit isn't nhra legal, so they are falsely advertising there. legal is a sealed, vented to outside box and no j-bolts.
i think i'm out of 2 gauge anything, and at this point i should probably build my own box because it's for a possible challenge effort, so budget is a concern.
grafmiata
grafmiata SuperDork
8/14/14 8:37 p.m.
Pat, I have 50' of 2-Guage I ordered from RPW a couple months ago, and I only need about 6' of it, maximum.
I can spare some for a Challenge-car.
MichaelYount
MichaelYount Reader
8/14/14 8:46 p.m.
I used 1/0 welding cable on the 13' run to my starter. A relatively inexpensive source of 2 ga. is to source a set of jumper cables. In fact, you can remove the clamps, join both cables on each end and run a 'double' - 2ga, 4 ga. - whatever is available.
irish44j
irish44j PowerDork
8/14/14 9:09 p.m.
I use 4-gauge in my 09 WRX with the battery at the back corner of the trunk. Cranks a little slower than stock, but hasn't been a problem in the 4 years it's been like that. I got some high-end marine battery cable from my dad's Marina. Has really tough sheathing. They use 4ga there for 20-30 foot runs to boat engine :)
CGLockRacer
CGLockRacer Dork
8/14/14 9:22 p.m.
I keep reading the title of this as trunk monkey battery.
I used welding cable for my SpecMiata.
Ranger50
Ranger50 PowerDork
8/15/14 7:57 a.m.
1/0 welding cable here. Terminated the ends with marine grade hammer crimp ones. Worked like a champ.
t25torx
t25torx HalfDork
8/15/14 8:18 a.m.
I'll give another +1 for the welding cable. While not quite the same situation, I redid all the cables on the 6.5L TD in my truck with this stuff and it's awesome. Cheap and super flexible.
patgizz
patgizz PowerDork
8/15/14 1:13 p.m.
grafmiata wrote: Pat, I have 50' of 2-Guage I ordered from RPW a couple months ago, and I only need about 6' of it, maximum. I can spare some for a Challenge-car.
appreciate the offer, will keep you in mind. i'm not sure exactly which route i'm going to pursue as of today. plus i swear i had some 1/0 cable from a car i parted last year, but it may have been scrapped for some stupid reason, like i was sick of having a trash can full of spare wires sitting around clogging up the floor.
TeamEvil
TeamEvil HalfDork
8/15/14 1:37 p.m.
"Whatever the welder cable size is at the local Tractor Supply store."
That's what everyone uses around here. Cheap and perfect for the task.
KZpb7dF5ukbdrKPel5QtoDiRPE9sxqtt2MWNgiTBfEahKuooY2CTEnk0qr9stdww
