paranoid_android74
paranoid_android74 UltraDork
4/23/17 6:24 p.m.
I can't quote actual pin sizes, but if you take a tiny screwdriver and slide it into the plastic connector on the wire side you should be able to unclip the crimp connector, slide it out and measure it.
RXBeetle
RXBeetle Reader
4/23/17 7:57 p.m.
I'm pretty sure that's a Molex Mini-Fit Jr. connector
This should help - Mini Fit Jr.
mck1117
mck1117 New Reader
4/24/17 1:10 p.m.
I'd check that the keying is correct, but it looks exactly like a 24-pin ATX computer motherboard power connector.
scooterfrog
scooterfrog New Reader
4/24/17 1:14 p.m.
mck1117 wrote: I'd check that the keying is correct, but it looks exactly like a 24-pin ATX computer motherboard power connector.
my thought
edizzle89
edizzle89 Dork
4/25/17 6:38 a.m.
another good source for wiring pins are large truck shops like Freightliner or Kenworth. In my line of work i deal with custom harnesses that need to adapt to factory harnesses and big trucks use basically every kind of harness pin in the book. I have had decent luck with just taking a pin in that i need to match/find a mate to.
E7wQOAuju5bKwW5dRh3NAHSDnPXKJur9zTdPo2p9maK2wMKPpE1GwHqpyFdixwqE
