Graefin10
Graefin10 SuperDork
9/20/15 3:54 p.m.
I know from personal experience that it's a good idea to turn the petcock off on a carbed bike. I bought a 250 Ninja that had a fully warm engine when I arrived to look at it. It ran OK when I tested it. Turned out that the carb bowl needles leaked enough to fill the crank case with fuel which ruined the engine. It was hard to start with a cold engine due to low compression.
Lesson not learned very well though because I don't turn it off on my current V Star 250. I checked the oil level several times right after I got it to make sure it doesn't leak.
ae86andkp61
ae86andkp61 HalfDork
9/20/15 11:07 p.m.
For me it is always the kill switch to keep the muscle memory and keep the action instant and natural when E36 M3 hits the fan; no problems to report so far.
So...leave it in gear, clutch in, kill switch, key off, petcock off (gravity-fed carb.)
Start procedure is petcock on, key on, shift to neutral, choke on, start.
Always the same means it is burned into memory and eliminates berkeley ups.
bav8umvmqloJkTQVntqK0l49ZjUtAHac6rcpIpSfyymNZBe2WHJfXgg9YdSZU7Ln
